Which Box Hill Segment is that?I haveLooks pretty legit. He's done a 6:25 up Box Hill (in real life) and he is 95kg.
Magic Bkool WattsOnly 451 watts for half an hour? Sounds doable
Good point, if my power meter proves to be reliable then your right I don't need to purchase an expensive trainer.Whats going on, Marino? Do you think both your trainer and power meter are faulty now?!
If you have an accurate power meter (and Stages is considered accurate) then you don't necessarily need a top end trainer, you can use a cheaper one to give you some dynamic resistance and use the reading from the PM in game for accuracy. Thats what I've done for a while now and it works well. I moved from an entry level to mid range turbo recently, but I'd say that if you'll be using a PM then why pay for improved power accuracy in a top end trainer when it won't even be used to record power?!
317 watts for 33 minutes ..... I was flying that dayI raced it on Bkool YEARS ago but can't remember it! Yeah, looks like there's a few short uphills but it finishes lower than it starts so more downhill than up. Bet you're even more tempted now @Joffey
Yeah, I've had a look at wiggle ... They are still bloody expensive, and the single sided option .... ermmmmmm ... I'm in contact with the guy on faceache that Brendan posted ... £380 plus the cost of two pedal body sets, and I'm all set upThere are selling the single sided SPD ones on Wiggle now and you can get 12% off![]()
317 watts for 33 minutes ..... I was flying that day![]()
Nooooooo, that's legit, honestAny results older than October 2019 can safely be disregarded, especially if done on a BKOOL trainer (Classic, Pro 1 or 2).![]()
I'm not a technical expert or 'ought, but I think you might need some spokes tooNew all season carbon rims have arrived
68mm deep, 35mm wide, 28h
Onto hubs now
View attachment 580417 View attachment 580418
Looks like from that table that I was the only one with realistic watts at the top-end of the table. Yet somehow they propelled me to third.Magic Bkool Watts. Bkool - and Bkool trainers were notoriously innacurate - and generous - back then.!
I'm not a technical expert or 'ought, but I think you might need some spokes too![]()
But your existing trainer does the job of dynamic resistance, just with a bit of noise that Elite say is normal? Not sure you really need a new turbo at all?!good
I will look into the cheaper alternatives, thanks for showing me the light.![]()
