looking at his HR, he is cruising like 17-20bpm below max
Ill record him next time, if I can lock onto him at the start
He may well fall foul of the new anti-sandbagger rules which look at 1 and 5 min power as well.
No, only 83kg which in C isn't 'massive' (the guys in the previous league were 100kg and averaging 300+ watts in a race for the whole raceProbably a heavy rider?
Thanks for the advice I’ll try and do that.Fantastic results all round - congratulations everyone.
Looks like the podium is already taking shape in C Cat, and 1st place might be up for grabs in D Cat!
@Marino.g - looking at your power numbers, you are only just tipping the scales into C Cat territory. So I agree it's probably better to stay in D for now but you will need to practise your race craft to reduce your avg power but stay in the race. Coast on downhills, stay in the draft at all costs, and equip the most appropriate frame and wheels available for the best speed with lowest power output.
The next DBR race is two laps of Richmond UCI circuit. Richmond will be available to ride on 23rd, 24th, 25th so you could join a D Cat race on the same circuit on those dates and practise your race craft so you know what it takes to be under the 2.5W/KG limit?
Team CycleChat have an opportunity to win the league in D Cat - it might feel weird but the best way you can help them do that is to back off in areas that you can afford to do so (see above) to stay in that D Cat power range. You probably won't be challenging for the podium if you stay in the required power range but you will be contributing to a possible win in the league, and improving as a racer![]()
Looking at his stats in ZP, he is not much different from the other front runners. He is either just taking the racing comfortably or doesn't want to push so hard in the B cats. Just curious due to his private strava settings. He does race a lot so may have mastered the art of 'true draft'He may well fall foul of the new anti-sandbagger rules which look at 1 and 5 min power as well.
Looking at his 20 min, 5 min, 1 min, 30 sec, 15 secs vs mine we're very similar. He clearly knows these courses really well, where to put the power on and where to hold back. Might even be as simple as I put on too much power when in the blob whereas he is more controlled and uses less energy for the same speed.Yes, he is at 83 kg. I coasted a lot going down Box Hill yesterday second time around, as there was no one to (possibly) catch and no one closing in fast enough. I think that lowered my avg. wkg quite a bit.
That is a real bugger! Shame about the bluetooth limitation too. Fingers crossed it arrives before the next DBR race and you don't have trouble getting hold of one.I tried switching to bluetooth but read later that it is a known limitation of the Powertap pedals that Zwift over bluetooth only picks up the L or the R pedal and doesn't use the combined number. So I could have raced at half power but that seemed a bit pointless![]()
25th on the road will be significantly higher on ZwiftPower though - some riders won't be registered, and others will be DQ'd so 25th may even be a top 10!Thanks for the advice I’ll try and do that.
There are so many sandbaggers in the D group and when in your in 25th place it seems like your not doing very well.
As it stands you will be DQ'd if you are over power for the entire event/race, and I think you get promoted into the next category if you consistently achieve over 2.5 for 20 minutes - someone will correct me if I'm wrong there!That’s what the Dbr rider does every week he keeps under the limit and doesn’t actually race.
Just to be clear is it 2.5kg for 5, 10, 15 or 20 minutes.
Shows, despite racing on here now for a few years we all have something to learn![]()
As @BurningLegs alludes to above, it's complicated and it doesn't help that the rules are in flux as well - they seem to change on an almost weekly basis at the moment, with a new amendment coming at the start of May.Thanks for the advice I’ll try and do that.
They’ve taken my placing away from me again this morning.
Don’t get it when you have a good race and they say it’s too good and moved me up to cat c where I would be in the bottom 5.
I’m done with the virtual racing game but I’ll be back next week to help the Cat D team.![]()
They've started allocating the points for the KOMs last night, but haven't completed it yet - in the categories I've looked at so far, only the leader has been given their points. However it is worth noting that ONLY the Box Hill climb is being counted, not the lap banner at the end of the first lap (that's an official confirmation from a DBR guy on the forums).
Fatigue![]()
So despite my bad performance (wkg) I did sweat a lot!
