Lee's sub 1 hour time was on the Neo I thinkLee has dipped under the hour, 2 mins faster than Al but was than on a bkool pro?
Off subject I know but. Neo 2T worth the extra £250??
blimey- all to play for then 😀Lee's sub 1 hour time was on the Neo I think
There are quite a few stories that the NEO2 is 20-30 watts lower than powermeters .... might be true. Might not be. At least no one can say now our trainers are over reading power ala the ProsThese are the difference between the 2 and the 2T according to dcrainmaker. To my mind these are really very marginal gains. especially if you don’t train in erg mode.
– Stronger Magnets: This gives it the higher torque that eliminates the slip
– Thicker Wiring: This reduces the heat output and improves efficiency
– Changing Wiring Topology: This reduces vibrations but also reduces the sensitivity of manufacturing tolerances
– Skewing of Magnets: This reduces vibrations and sounds
– New Magnet Holder: This helps in manufacturing by increasing position accuracy, but also reduces vibrations
there are quite a few people on the Facebook neo group saying the neo 2 power readings are a bit off compared to neo 1. And also vary a bit from one trainer to the other. But... it seems to be a common theme amongst these communities.
I have noticed at a beginning that my Drivo2 holding my power somewhere instead of unleash themThere are quite a few stories that the NEO2 is 20-30 watts lower than powermeters .... might be true. Might not be. At least no one can say now our trainers are over reading power ala the Pros
I bet they're not though! (with the possible exception of a small number of faulty units)There are quite a few stories that the NEO2 is 20-30 watts lower than powermeters .... might be true. Might not be. At least no one can say now our trainers are over reading power ala the Pros
Excellent .... so my FTP should be closer to 270 rather than 230 No wonder those with the NEO1's are beating me in racesIts more like 40W down
I think I will be doing something similar. It's just sooo boring doing endurance rides on the turbo. Helps a bit if there's a suitable group ride to join.Im finding it OK Tommy. I'm using traditional endurance base program, to recapture my cardio fitness. Week 3 so far, then a easy week before jumping up a level. I've decided to do the odd race(noticed) to peak up my VO2 at the same time this winter. Planning to keep at it till Christmas, then onto a build program to add power. My average watts jumped around 10W from last week, so improving. I do use Zwift as the entertainment on the long rides.
You and Tommy seem to have sneaked in from behind. Can't keep up with Tommy on the hills now and working hard to keep up with you.There sure is. I was looking ahead to see if any other riders on the course were riding at 3w/k in hope I could ride and draft but they weren’t so hopped from one or the other. Still, it’s. A great workout and a 4w threshold increase😂
Looks like you are as strong as before the surgery
