youngoldbloke said:To return to the OP - worth reading the following which answers most of the questions re. bike fit:
http://www.chiropracticperformancecentre.ca/Handouts/Lifestyle/Road Bicycle Fit.pdf
velocidad said:this is driving me pottyi've tried every method now and they all come out with completely different results.
jimboalee have i got you right? are you using your leg length (standing height - sitting height) and using that x 0.883 ?
if so that gives me 170-87=83cm 83x0.883=73.3cm measured from the centre of the BB to the top of the saddle surface. this gives me a crazy high saddle, i'd need platform shoes to ride it![]()
jimboalee said:If you're inside leg is 78.5, that's 46% of your height. That sounds medically abnormal.
Are you using LOOK type pedals?
Try the sitting method again and multiply by 0.875. ( 7/8 ).
jimboalee said:Dunno. Worked for everyone I've set up a bike for.
Sitting height is straight forward. Can't make a mistake, unless you clench your buttocks.
