roadiewill
- Wiltshire
so...
Randochap said:Incorrect. But feel free to use that for yourself.
The point is that there are no absolutes in bike fit so the advice I've forwarded will indeed get most people within a centimetre or so. Are you claiming your "slightly bent w/ heel" is more accurate?
Yes Will, a tailor would measure from the middle of your crotch to the floor in stockinged feet. I have no doubt that the experts will correct me when it comes to bike fitting, as it will differ depending on how thick the soles of your cycling shoes are.roadiewill said:so...
Dave5N said:No, I'm claiming that 'within a centimetre or so' is not good enough. My starting point is a good starting point and works well week in week out with very many riders.
So there.![]()
) and squaring the front of the book on the wall. Measure (help from friendly female?) from the floor to the top of the book spine. Do this several times and split the dif. That's your standover. Multiply by .883.asterix said:..but if it is a starting point then, Shirley it permits a certain amount of further adjustment?
Dave5N said:Yawn
Randochap said:Notice how Dave5N, whenever he's caught out, suddenly comes down with a severe case of narcolepsy. My theory is he's dozing most of the time, which is why his advice can't be trusted.
While I'm at it, here's more on why his advice on saddle height is dead wrong (in fact barse ackwards):
If you tell someone to have their leg "slightly bent" at 6 'Oclock with their heel on the pedal, that will in fact give the most imprecise fitting.
Think about it. "Slightly bent" is a very ambiguous term itself. "Straight" however is much less prone to misinterpretation. That's why we choose the heel on the pedal/straight leg approach ... because, when the foot is placed properly -- ball of foot/metatarsal over pedal spindle -- you will then have the percentage of slight bend needed for comfortable and efficient pedalling.
If you followed the imprecise "bent leg" advice with your heel on the pedal, it's guaranteed your saddle would end up too low and you'd be asking for knee issues over the long term.
Incedentally, here's another interesting way to find a ballpark saddle height:
Put your arm over the bike, with the apex of the saddle in your armpit. Reach down to the BB and extend your fingers. The tip of your middle finger should reach the spindle centre. It's amazing how close this will come to most to other technical measurements. I hear Indian bike rental guys use this method!
That's all for now.
On edit: BTW, no gender-centricity meant by comment in last post (directed at a reader with testicles). The above method works equally well for women cyclists. That particular part of the anotomy (perinium) is gender neutral. If you like, get a male assistant to help w/ measurements ... assuming you are ... ho boy this can get complicated ....
Dave5N said:It's not narcolepsy, it's because you are a tedious, self-important old bore.
Randochap said:I'm quite happy to own my prodigious ego and advanced age.
Let's see you face up to the fact that you are a poor sport, don't know when to throw in the towel (due to your inflated ego) and hide behind internet anonymity to stalk people who challenge your sense of self importance.
This the simple answer to the OP's question was answered long ago.
