As power level increases, cyclists don't pedal in circles.
Martin cited 1991 research by Ed Coyle, et al, involving regional level competitors and elite racers -- pros and U.S. national team members. Coyle found that elite cyclists pushed down harder and pulled up less than the less-accomplished riders.
Surprisingly, the elite riders were more efficient even though they were pedaling less smoothly. They had a higher percentage of endurance-loving slow-twitch muscle fibers than the regional riders and Coyle theorized that may have skewed the data regarding efficiency.
To find out if Coyle was right, another study examined 8 different riders with similar muscle fiber makeup pedaling with 4 different techniques: (1) their normal, preferred technique; (2) concentrating on pedaling circles; (3) pulling up on the backstroke; (4) pushing down hard. Pedal forces and metabolic costs were measured.
Pulling up was significantly less efficient than the riders' preferred technique. The study indicated that the muscles that flex the leg and allow pulling up the pedal on the backstroke are intrinsically less efficient than those that push down.
How can your pedal stroke be efficient if the weight of the foot and pedal on the backstroke interferes with the power-producing downstroke? As the study put it, force and power at the pedal reflect the combined effects of muscular effort, gravity in the form of the weight of the leg, and accelerating and decelerating the leg during the pedal stroke. In other words, the negative power observed at the pedal on the backstroke is mostly due to gravity, and that negative power is essentially balanced by the weight of the other leg.
So is it worthwhile to concentrate on perfecting your pedal stroke?
Martin maintains that when we pedal we use the spinal cord's neuromuscular programs that allow us to run. Thinking about the fact that these reflexes exist and are useful for pedaling is usually sufficient to ensure a solid pedal stroke.
Broker agrees, saying that he isn't a believer in working excessively on the pedal stroke in training. When he was helping coach the U.S. national team in the '90s he simply gave riders a few cues at the top and bottom of the stroke to help them visualize a smoother "circle." For instance, as the foot nears the top of the stroke, you could think about pushing your knee toward the handlebar. And as the foot nears the middle of the downstroke, use LeMond's timeless advice to pretend you're scraping mud off the sole of your shoe.
Notice that these cues are activated well in advance of when the foot is actually at the top or bottom of the pedaling action. That's because you can't react fast enough to put the movement into action when the foot is farther along. You have to anticipate the proper moment and visualize the cue well in advance due to the speed of pedaling. Think about passing a football. You need to lead a running receiver, and in the same way you must mentally "lead" the foot in order to get the desired action at the right time in the pedaling circle.
Another way to get feedback is to ride a mountain bike up a steep hill with a loose, gravely surface. If you pedal jerkily, pushing down hard, you'll lose rear-wheel traction. The tire will spin abruptly on the loose gravel, causing you to lose momentum and put a foot down. But if you concentrate on pedaling evenly through the whole 360-degree circle, the rear wheel won't lose traction.
Interestingly, said Broker, among all the riders tested over the years at the U.S. Olympic Training Center in Colorado Springs, mountain bikers had the smoothest pedal stroke, even smoother than pursuit specialists on the track. Off-road legend John Tomacwas the smoothest of all.
Fine. Some practice, rather than years spent working on a silky pedal stroke, will make you as smooth as necessary for generating maximum power. But how much practice do you need?
