Sorry if this is in the wrong sub-forum.
As I await my new bike I’ve been doing some online ‘research’ into a few extras.
One is for some form of navigation.
I know there are three basic options here, 1: Human nav app. Know where you’re going at all times, 2: Use an app on your phone, or 3: Use a specialised cycling nav computer such as a Garmin.
From reading a little it seems that it’s too much to ask for a nav tool that has accurate pre-loaded maps, options to avoid main roads (that actually works!) and (1) an intuitive and easy to use interface.
I’m not interested in pre-loading routes, (2) nor do I want to become a software engineer in order to use the darn thing.
(3) I’d like to disappear into the local countryside and use the in built maps and nav to get home (or to anywhere) should I get lost or just wish to go somewhere but don’t know the way.
I’d like to just set it like I do my car nav, but for it to be cycle friendly and not send me onto dangerous and busy roads (for example just sticking to B roads or country lanes but to also avoid any off-roading).
(4) Why is this such a big ask and why is it seemingly necessary to mess around on complicated settings to even try?
I read so much about so called road avoidance settings simply not working or not being available. This should be a standard and reliable feature of the device or app is sold as for cycling.
I fear for any astronauts being sent to Mars if we can’t even provide a reliable navigation tool for a cycle?
Perhaps I’ve totally missed something here but willingly await education on the subject.
Thanks.
The points in red I suggest you don't do:
I would advise against this as it means mounting an expensive device on your bars, one which might not survive a crash or navigation could deplete the battery. In both cases you could find yourself in an emergency situation without a phone. A Garmin will require you to become a software engineer.
The points in green are easily achieved with a Wahoo. A simple and friendly device to use. (1) Simple interface on a phone app. (2) You don't need to be a software engineer just able to use a very straightforward app. (3). I've never used it but Wahoo does have a "take me to" option - I've been on rides when others have used it with success. (4) as has been said there are physical limitations due to device size, however a Wahoo is not complicated to use.
I haven't done this but have friends who do and have in areas of the country they didn't know. I'm thinking in particular of two female friends who say they don't have a clue how to navigate. Going off on a week's cycling holiday they asked my advice and I suggested grabbing routes for the area from Komoot. They came home to thank me and talk about the fantastic routes they had ridden. All do is link Komoot to the Wahoo device and the app, select rides you like and these automatically sync with your device. You can then select a route from either the device or the app. Strava and RWGPS will allow you to do the same but for this function Komoot seems to be the best.
I often plot routes for my home area, Lancashire, but I can ride all day, 100-120 miles without any navigation help. This is simply experience and local knowledge built up over years. If I was riding an unknown area without navigation I'd jot down a series of village names in a roughly circular route and keep heading for each in turn.
None of this is tricky but if all you want is a device with pre-planned routes you won't go far wrong with Komoot and Wahoo.
