Now what you need to do is follow this regime.It's clean?!
I already used half the can of degreaser, I don't think it can be cleaned much more?
http://www.cyclorama.net/viewArticle.php?id=349&subjectId=9
Not on the majority of my bikesNext time I do the process I'll use a rag and wipe down ,interesting that the outside of the chain doesn't need any lube as it just attracts dirt.
I applied to the rollers only hoping the outside would be fine without lube, that article confirms I did it right in terms of lube-ing the areas I needed to. Just to give it a clean up with a rag now seems sufficient.
I must add, the cogs are black normally and the chain is dark grey metal... no matter how much I clean it it'll never be shiny gold like some of the chains on you guys fancier more premium bikes than mines :P
Not on the majority of my bikes, there is only one with a 'posh' chain on it.
The trick is not to let the crud build up too much.![]()
5 minutes once a week, pump the tyres up and have a good check over the bike while you're at it.Yeah, that's where I screwed up! Plus that cheap lube I used was a spray, covering every (even the unnecessary parts) of the chain in sticky dripping oil ,attracting dirt and dust.
A lot of my commutes are in nice nature-y areas where plant buds etc stick, i notice them stick to my whele.. no way my chain is spared from it!
Just need to keep up the regular maintenance of the chain!
OK, we'll call it "The method formerly known as the Mickle Method" to save your blushes.Can we call it something else now?
To be fair he only told people how to do something from years ago, before all these chain cleaning dooberries were foisted on unsuspecting affluent 'newbies' who were told "You need to buy one of these"OK, we'll call it "The method formerly known as the Mickle Method" to save your blushes.
Some people! Develops and promotes practices that saved an entire generation of cycle chains then gets all coy.![]()
Same here, degreaser can do more harm than good if you're not careful. A slightly dirty chain is better than a dry one.I never use de-greaser. Just lube up the chain, and wipe and wipe more with rags. Any gunk inside the links can be removed with a small screwdriver, or a brush. Don't let it get that dirty again.
Also clean in between the cogs of the cassette with the edge of a rag.!
