Which Best Stand/floor pump
Sharky
Kent
Curious, I have a Halfords, car air compressor.
Works great with the car, but never attempted with my bike tyres.
Has anybody?
Seevio
South Glos
Has anybody?
I haven't tried and it may be totally fine. I would advise caution as car tyres have much higher volume than cycle tyres. This means that the same amount of air results in a much higher pressure change in a bike. It would be very easy to go dangerously high.
Of course, this is if your car compressor can deliver the higher pressures typically found in bike tyres.
si_c
Wirral
I think some of them can, but I'd be curious about how easily they achieve it, I'd expect the majority of them to struggle reaching anything around 100psi.
I've never tried to use one, I've managed perfectly fine with a regular foot pump that we keep in the boot and despite having a 50l compressor in the garage I rarely use it for pumping up tyres - just seating the occaisional tubeless tyre on a rim.
Dadam
SW Leeds
It's not a question of "amount of air". Pumps don't just try to fill X litres of air like filling a bucket. They work until they reach a certain pressure. I imagine one for domestic car use would not be dangerous. I doubt it would shift enough volume quickly enough to get to dangerous levels before you noticed, but obviously I wouldn't leave it unattended. Mine takes a good few minutes to fully inflate a flat car tyre. It doesn't state a maximum pressure but the manual does suggest a pressure for mountain bike tyres 30-50 psi and road bike 90-100, so this implies it can do these pressures. However mine works by setting a target pressure where it cuts off so this should be ok.
A garage one would certainly need care as it would deliver the volume quickly
MontyVeda
I bought a Halfords pump about 10 years ago. It works. There may be better pumps out there but my tires are inflated.
I got one from Wilko about 15 years back. All plastic but only cost £7 and looked like it'd break in a few months... it's still going strong.
Y
YMFB
I tried and failed to find a connector for my Giant stand pump so bought a SKS Rennkompressor from one of our LBS, mainly because it was the best one in both shops.
if anyone knows where I can buy a new connector for the Giant I’d be grateful.
ColinJ
Puzzle game procrastinator!
The second one was weird though as I deflated an inner tube to swap the wheels around, but when I put it on the new wheel (in the same tyre) it blew itself up as when I checked it was a 700x28c in a 700x42c wheel so no idea how it had not blown up before.
Every time that I have HEARD(!!!) that happen it was either due to a rip in the tyre (which I am sure it wasn't in your case) or (more likely in your case) the person inflating the tube not noticing that it had been pinched between the tyre bead and rim.
Dirtyhanz2
I have got a joe blow had it for about 10 years works great
One day I am going to buy a vintage silca the true gold standard in pumps
wiggydiggy
The first one definitely, that blew a few seconds after inflating and gave me a nasty shock lol. The second one stayed up for as long as it took me took me to tidy everything away, and blew sometimes overnight. Bit weird.
andrew_s
Gloucester
There's no need to replace the whole pump if it's just the valve attachment that's failing
There are replacement heads/chucks widely available, and the hoses are all fairly similar so there's generally no need to stick with the same brand.
e.g.
https://www.freewheel.co.uk/truflo-track-mate-high-pressure-track-pump-head-qa4900
https://www.leisurelakesbikes.com/accessories/pumps/topeak-joe-blow-twin-head-replacement__30937
https://www.sjscycles.co.uk/pumps/topeak-twinhead-pump-head-hose-upgrade-kit/
Would it be possible to fit a different brand of connector to the Giant? A rubber pipe is a rubber pipe, and if the internal diameter is right…then a Jubilee clip and away you go.
Anyway I bought a SAPO (£11) in 1978 and a couple of new connector rubbers and a leather plunger washer later it’s still going strong.
