All very interesting
@Yellow Saddle. Reliability is the key for me and while reading your post I immediately thought about a Dura Ace hub that I bought on gumtree over a year ago and I fixed the other day by replacing the loose ball bearings. I'm pretty sure the ball bearings I used were just ordinary ball bearings, probably grade 100. I was very happy that the gamble I took paid off.... the hub was only £10 and it is in great condition, only a few balls were damaged. Now, that I'm using ordinary grade bearings am I at risk of damaging the racers? Assuming they are correctly tightened Which brings me to the other point, I now have 2 full sets "digital" adjusting Dura Ace hubs and what you were saying about the importance of correct adjustmet is going to be tricky as I'm not sure whether to follow Shimano guidelines and adjust the cone so that there is no play, when I now know that if I leave a very small amount of play and I close the QR tight while the hub is on the wheel stand, that small amount of play is now gone. There is very little information out there on adjusting these hubs. Shimano guidelines are clear and easy, that is why they came out with this system, adjust until there is no play. I guess, untill there is more feedback on these hub I'll have to follow the guidelines and monitor the hubs closely.
Thanks ever so much for all the information. It's great stuff.
Don't worry about the Grade 100 balls in there. But regularly spin the wheel by hand as I described and feel for broken balls. Just in case.
I'll answer the digital adjustment question of yours, which I think is valid, with a general description of how to adjust the wheel bearings. You'll immediately see how to test your "digital" setting as well.
1) The key to adjusting wheel bearings on wheels that don't have on-the-bike adjustment systems like Campag or Fulcrum, is to have just the right amount of axle play when the wheels is off the bike, so that when you clamp the QR, that play goes away.However, you don't want negative play because that would then overtighten the bearings. The latter is hard to judge.
2) Clean, replace, reassemble the bearings and start adjusting. Feel for movement by strongly buy slowly wiggling the axle up and down. You want to be able to feel a little bit of mechanical movement in the axle. How much is "little"? Trial and error will tell you. Don't worry, you won't get it right first time and even if you do, you won't repeat that trick the second time, I promise you that.
3) Once you are satisfied that your cones are just right when the jamb nut is tight. proceed to install the wheel.
4) Make sure nothing on the bike touches the wheel. Brakes open (disc pads out if needed) and chain OFF.
5) Install the wheel and lightly tighten the QR. Conform that the wheel still has play by moving the tyre end sideways and feeling the feedback from the cones bashing against the balls inside the hub. You will have about 1mm movement at the tyre.
6) Now open the QR again, crank up the nut and close it forcefully. It should leave a white mark in your palm that will disappear over about 10 seconds. Don't put the QR lever in line with a frame tube, because it will be so tight that you will struggle to get your fingers in there and open it.
7) Now conform that all movement has gone and the pay has been taken up by the compressing axle. There will be no play anymore. Don't confuse wheel flex with play. Play gives mechanical feedback, flex doesn't
8) Now you are sure that it is not too loose, but is it not perhaps too tight? Let's test.
9) Slowly spin the wheel - very slowly and watch it come to a stop. Note what part of the wheel settles at the bottom. It should be the heaviest, like the valve (or in tubeless, the congealed mess of sealant inside).
10) Repeat the process in 9) and see if it settles at the same place again. If it does, you know the cones are just right. If it settles randomly, the cones are too tight. Remove and repeat the necessary steps.
Campag wheels allow you to adjust the cones on the bike and lock the cone with an allen key. This is nice and quick. Great system.
On your digital wheels, you should still test if it is too loose or too tight. But I suspect the process will be much easier, especially after the first time. On standard wheels it isn't easy and don't expect to get it right first time. But it is important. Practice.
