Ming the Merciless
There is no mercy
- Inside my skull
The performance benefits of sti far outweighed any weight penalty though.
Weigh more than separate brakes and shifters, don't shift as well, chew cables. That sort of performance?
Note the down tube Campagnolo shifters operating a ten speed cassette via a Shimano Tiagra medium cage derailleur . Despite initial fears of will they won't they cope l can assure any doubters that they are a pleasure to use and take only very small movements to change gear in a most satisfying way .Weigh more than separate brakes and shifters, don't shift as well, chew cables. That sort of performance?
If l owned a bike as beautiful as yours l dont think l would care what it weighed.....that is fab.After reading this I weighed the Colnago Master Olympic I have. Its a 1990/1 Columbus Gilco frame with a newish 11 speed campagnolo Potenza groupset and Ambrosio Excellight rims on Chourus hubs. Came up as 10.005kg all in.
Damn, that must be why I was so slow... mine weighed 21lbs (5 gears only). The fixed wheel track bike was only 19 though.Whole bike under 20 lbs
Don't actually know what my bikes used to weigh in at. The 20lb figure came from my dad, who used to race fixed, so for a geared bike your 21 lb is probably a good racing weight.Damn, that must be why I was so slow... mine weighed 21lbs (5 gears only). The fixed wheel track bike was only 19 though.![]()
Well that was the H.E. Green, so I expect it was about as light as they could be in the mid 60s. One chainring and only a five speed cassette probably helped too. Everything that could be was alloy. Sprints & tubs too.Don't actually know what my bikes used to weigh in at. The 20lb figure came from my dad, who used to race fixed, so for a geared bike your 21 lb is probably a good racing weight.
Looks like you've tried to "stretch" a small frame with the long stem and layback seatpost. If the frame was bigger and a normal seatpost and shorter stem was fitted, I wonder if it would turn out any heavier?
I already said that the performance advantages outweighed the weight penalty. But as an early adopter of sti back in the early 90s, I don't recognise any of those other issues. The real benefits were being able to shift without taking your hands off the bars/hoods. Priceless in a sprint finish. I don't remember anyone ever moaning about the 'weight penalty' back in the day, because we all knew it was irrelevant.
But most riders don't race and aren't in bunch sprints needing to change gears. Not shifting your hands becomes a performance disadvantage at long distances. It's a good thing to move your hands around the bars. So if you're not racing you mostly get the disadvantages and not a lot from the advantages.
My lightest steel framed bike. Reynolds 853 SBDU Pro frame. Short tight geometry and a joy to ride. Deserves lighter, more expensive wheels and components but I'm too tight.
