One of those days to be doing bits, and getting frustrated at the same time:
My
Olagnero frameset's been sat for about 6 months doing nothing with a too-big seatpost rammed into it that won't come out as it's seized and rusted. I've given up having tried many things. And it needed too much work to be sent to the Seatpost Man. So ... I tried removing the forks. Also seized and I got a bashed and bleeding knuckle for my trouble. It's going on sale as is and the buyer can try to remove the forks
. At least I have the Shimano RX100 groupset and Mavic Reflex wheels it came with which all work.
I then tidied the wheels in the parts shed as two new pairs of Superstar Components wheels, for next winter, are taking up space. Two full wheelsets out to be sold (a single speed set with new tyres, a used Superstar red set with tyres) and a
very worn Fulcrum Racing 1 plus 1-4 other wheels as possible sales.
After a coffee and some Christmas cake I set onto upgrading my Holdsworth Roi de Velo crankset for the second time. Pedals, cranks, bottom bracket all came out easily - which was a relief. Then the problem started; the bottom bracket I
thought it would take (a Dura-Ace 9000) wouldn't fit the crankset. At least I tried it before fitting. So, left as is and what I
think is the correct bottom bracket now has been ordered and is on the way. To be continued and I have until January 17th to get it all done ...
Finally, the Peugeot Optimum I picked up about 8 months' ago had a seeing-to. Note to self: don't trust a seller who asks for money up front.
Why? Well the 'fully working bike' turned out to have seized gears, a seized seatpost, a seized stem and bars plus the original 20mm tyres from 1990 which were massively cracked all over. Oh, and the saddle clamp was missing a bolt. Eight months ago the seatpost and stem were un-stuck and re-greased where needed, saddle sorted out, new gear cables in Then I tried to take the pedals off as they were old flat ones. Left = fine, plus the crank off easily so I could have a look at the bottom bracket. Right = seized
. The crank = seized, cross-threaded and it broke my puller, which also stuck in
. So it was put away for another time.
Today I pulled it out, got as much of the damaged puller cut off as I could and then put used tyres on. It'll be ridden until the crank comes off, if ever, when I'll get the pedal off or replace the RH crank. The work is
possibly worth it as the whole bike's hardly used and is main-tube-and-forks 531-framed, but hasn't been stored well since there's quite a bit of rust all over.
