Had a fair sized gash in my rear Gator for the last 2000 miles or so, had it reinforced with some Teflon weave stuff we had at work, remarkably strong stuff....but i had a sudden deflation about a mile from home yesterday, so that was going to be the first port of call.
Yep, sure enough that was it. Closer inspection showed the hole now has clear light passing through it, so i thought it's a visit to the LBS, then remembered ive got another gashed tyre in the shed...and found a good Gator on a spare wheel
Puncture repaired, tyres swapped over and found its real real easy to remove glass and shards from the tyre when its off the wheel, just pinch around the hole and the glass falls out.
Going to oil the chain in a while.
Non cycling...the wife was cleaning a rug with the daughters Vax, suction wasn't very good. A little investigation showed the gasket on the suction side has deformed, giving a bad seal. Re-fitted the gasket and its much better. Told the daughter we'd get her a new gasket...you can't buy them
Going to have to make one out of something...poor service from Vax, a £2 item that'll render a machine useless...and they don't supply one.
All this was with the aid of three cuppas...
