- The TerrorVortex
Parsley is a bit of a waste of thyme IMHO.
*gets coat*
*gets coat*
You're missing the parsley![]()
after about 50 miles the creak came backreplaced the pedals on the carbon for another set i found in my parts bin 2 days after ordering a new set, the old set was definitely worn as the outside of the pedal where the shoe rests and the cleat twists out over had a groove in it .
I do like my cleats tight so im guessing over time it wore a groove as i unclipped and they were second hand to start with and now the was a squeak as i pedalled that no amount of lube could stop for more than an hour or 2 and the pedal was a bit loose even on max tightness
I had that happen on a 100 km ride in Devon on Thursday after 50 km, only in my case it was on the left side. I noticed that the sole of the left shoe is much more worn than the one on the other side. Damn annoying! A squirt of GT85 on the shoe's sole and the pedal shut the row up for a while, but it came back for the second half of the ride. I'll have to see if I can find a more effective solution. Slightly realigning the cleat might help, but the allen bolt holes are worn so it might be tricky to loosen and retighten them.after about 50 miles the creak came back
its only the right shoe which is odd , i will try altering the cleat angle a bit but looking at the shoes i have had them years and the inner heel is worn inside so maybe this is a factor ?
I had read that SRAM recommend taking the BBs out and cleaning and regreasing the seals every 50 hours of riding. That tells me that the seals are very poor,
That would mean taking my commuter bike to bits every few weeks.
This is a problem I've come across before; many components are designed for leisure use, not for people using bikes as transport.
This was brought in by a chap who wanted a service. I have never seen one so bad and its a road bike !
The smaller jockey wheel was rarely moving which is why the mud is not so polished. Just keep coving the mud in WD40 and this is what it looks like.
Yesterfettles: attaching an air tag and holder to my Marin. It fitted perfectly, but the metal water bottle cage now doesn't fit without fouling the frame. So I need to either get a plastic bottle cage, or move the airtag holder to the front fork so I can have the bottle cage on the fork.
Plus air into assorted tyres.
Thought it was on upside-down but it's not. 😂
