- South Manchester
I assume those left ate tight and spin trying to undo. Have you one of those handy dremmel type tools - they are dead handy - you may need to cut a slot in the nut to 'hold' them.
That’s my plan . When I manage to get the bolts and now non captive nuts out.If they are definitely no longer captive, replace with standard bolts and tighten away...
Yes the remaining ones are loose and turning . I do have a dremmel , I will need to buy some cutting discs . Then cut slot for screwdriver. Sounds like a plan .I assume those left ate tight and spin trying to undo. Have you one of those handy dremmel type tools - they are dead handy - you may need to cut a slot in the nut to 'hold' them.
Thanks DC and Fossy . A few hours in the Velocave with my trusty Dremmel and Black and Decker and the problem solved . A bonus both the crank and the chainring survived unscathed.View attachment 657621
I have a fettling problem, I discovered I have loose chainring bolts . It’s a Stronglight 2000 track chain set with captive back nuts for the bolts. The Problem the back nuts are no longer captive , there is no way to grip them . So any suggestions that don’t involve destroying the chain set or chain ring.
@8mph Sounds like an excuse/ reason to buy more Tools .![]()
This was brought in by a chap who wanted a service. I have never seen one so bad and its a road bike !
The smaller jockey wheel was rarely moving which is why the mud is not so polished. Just keep coving the mud in WD40 and this is what it looks like.
