What Have You Fettled Today?
roubaixtuesday
self serving virtue signaller
Gears on the tandem were playing up, first couldn't get into smallest sprockets, then not the largest either.
Stopped at the top of a hill to investigate, no obvious issue could be found then *sproing!* the cable snapped whilst fettling, doubtless having been previously on the way out.
Happily, having suffered on a long ride once before, I learned my lesson and always carry cable spares (why wouldn't you - cheap and light) including tandem specific ones. Further surprised myself to learn that the multi tool screwdriver actually fitted the little screw that holds the panel in the brifter to remove the broken end that always gets stuck.
Not going to lie, it took a while, but all sorted at roadside, and near 50 miles ridden in all.
One question for ccers: lacking a cable cutter, I just coiled the excess, but for upcoming (hopefully) tours, I think a tool with pliers, cable cutter and maybe tweezers for this sort of job could be useful. Any thoughts or recommendation? Leatherman seem to be the go-to, but are there other better ones? Plus there's a gazillion different ones of those to choose from.
Repaired the holes in my Spesh BG Pro mitts I've had for years - put a few holes in it after a spill on Sunday on my best bike - biggest off I've ever had on that bike (in 32 years). Also been patching myself up - big nasty gash in left forearm - hydrocolloid dressing on from Monday until this afternoon (after a ride), removed, wound cleaned under warm shower, new dressing applied. Going to need more as it's a big wound (gravel rash plus removed skin from a blunt edge).
PS the bike was fine - needed a couple of tweaks of the spoke key.
Post patched up ride photo (mitt and arm)
ColinJ
Puzzle game procrastinator!
Does sound like the cassette now; trouble with these sort of noises is they could be from anywhere as the sound source is hard to pin down.
Well at least I am not going to get fooled by the saddle again... I learned that lesson on my singlespeed bike (one of the saddle rails had come loose inside the saddle itself)! I was still getting the noise on the Devon bike when pedalling out of the saddle.
I'll take my cassette tool and chainwhip down with me for my next visit at the end of September.
Overconfidentii Vulgaris
A couple of fettling sessions from last week:
Thursday: The knockabout bike has been showing signs of the middle chain ring being worn plus I wanted to nick the 24 tooth small ring off it to use elsewhere so, crank off, middle ring replaced with new, small ring replaced with a used 26 tooth and everything had a good clean while it was apart. I fitted a new chain and a cassette as the old one has done pretty well (over 6000 miles and three chains if my notes are correct) then turned my attention to the rear derailleur which was cleaned up and the main pivot relubed. New brake and gear cables plus brake blocks finished off the job.
Friday: It was the Raleigh's turn. Again, the middle chain ring is quite worn, but on this one I have some new zicral chain rings that I'd put on my birthday list as I wanted to alter the gearing slightly. Those have gone on with the one taken from the Hawk so the set is now 24, 34, 46 teeth. A new chain went on and even though the old cassette was probably fine to reuse I've put a new one on so that everything is new (old cassette has been kept for another occasion).
The rear derailleur had similar treatment to the one on the Hawk but I've fitted new pulleys to freshen things up (they've done nearly 15,000 miles). The old pulleys are in much better condition than I thought so I'll use those to refurbish a worn derailleur I have in the spares box. Having cleaned and lubricated the main pivot I found it a bit of a pig to reassemble this one and had to ask for a helping hand - hopefully I won't need to do that job again for quite a while. I've changed gear cables even though they seemed alright and to finish I've put a new Vittoria Revolution Tech tyre on the front to make a matching pair. All seems good after the first proper ride and I'm looking forward to racking up some miles with the new set up.
Lol, my only fettling today was to remove the TT bike from the trainer and pump up its tyres. I had been wanting to angle my elbow cups on my TT bike and hopefully spread the load on elbows (the small point load is causing a lot of numbness on longer TTs). Ordered the brackets and spacers to do so. Whilst the brackets came by courier, the spacers were sent Royal Mail and with them striking they still haven't arrived.
Andy in Germany
Back to work today, quite how I managed to get this job is still a bit startling to me, but I'm not complaining.
I did complain about the first bike though. It was a Victoria city bike called a Baden Baden and it looked in good condition; I don't know if Victoria are known in the UK; they make mid to upper middle range city bikes so I thought this wouldn't be too much trouble. The list of "Extras" included changing the brake blocks front and rear, pumping up the tyres and turning the rear tyre because it was on backwards.
Blocks changed the front V-Brake was looking lopsided, a turn of the wheel revealed that the wheel had so much buckle it could be a pair of boots. It took a long time and some swearing until I managed to get it to submit to laws of physics so I could reset the brakes.
Then I pumped up the tyre; the inner tube exploded. B*gg*r. Dropped wheel, looked for new inner tube with the same valve, checked wheel and tyre, fitted tube, pumped, bang. On inspection both had popped on a seam on the inside of the tube. I recall this has happened before so it could be the trouble was the batch of inner tunes, which could be quite old for all I know.
Okay then, different tubes, but that would mean a different valve type, so I'd have to change the back wheel to match; not the end of the world as I needed to swap the tyre. Found a pair of car valve tubes, and to be on the safe side, some rim tape. Mount tube, mount tyre, wheel back on.
Go to back tyre; it's a Sram hub gear because nothing can be simple with this bike. Unscrew bolts, drop innards of Sram on floor, retrieve, put in tray.
Colleague calls from the till, a customer has a question she can't answer. to till and back.
Remove tyre from wheel, swap inner tube, wheel back in droppers, pulling to tension chain with some difficulty, phone rings, It's my colleague at the till again: another customer has a question.
Wheel back on floor, go and sort customer out, back to wheel. Beginning to feel like Basil Fawlty.
Wheel back in droppers, tension, tighten, chain inexplicably slack, repeat. Works second time.
Set brakes, set gears, wonder of wonders I haven't lost any of the bits and they work first time. Time for test ride.
On cue it starts to rain, very heavily.
Test ride delayed to Monday, in the meantime fix an elderly Diamondback which goes surprisingly well. Knowing where all the tools are is a great help. Admittedly I knew some of them were at my apartment, but that's entirely my own fault for not ordering replacements for my tools...
Jenkins
Felixstowe
Went into the shed to get a bike out for use this morning and noticed that the Bootzipper 29er had a flat rear tyre. Having sorted that out I was putting the wheel back and lining up the disc rotor between the pads when I saw how little material there was on the pads which meant they had to be changed. Followed by the front pads when I checked them and found them to be very badly worn as well.
