GuyBoden
- Warrington
With different shoes on yesterdays ride, I moved my saddle 3mm higher, it was a big job, but I was up to the task.
Aaargh! I forgot that one of the spare BBs was Italian thread and tried fitting that... I switched to the English-threaded one, then forgot that I had turned the bike round so I was trying to screw it in the wrong way. I got flustered and put the left crank on the righthand side. I corrected that and then ended up with both cranks facing in the same direction!! Short of completely destroying the threads on the BB shell, I couldn't have messed it up more...I'm going to try putting a spare BB on my singlespeed bike to see if I can finally stop recent annoying noises from it. A new chain has helped, but not eliminated the problem. I think everything was wearing out at the same time! I'll report back later...
I just checked the bolts - they are tightIs the saddle tight?
I just have a rear mountain bike mudguard bolted on to the seatpost and that bolt is tight.You could try greasing the mudguard bridge.
One thing I noticed last night is that the noise seems to be worst when pedalling easily, and gone (or almost gone) when pedalling hard. Maybe it IS the freehub...
It is a strange sound. Not the usual clicks, clunks, or ticks - more of a clicky tinkling!
Some people might question why I am making such a fuss about a little noise. The reason (apart from it being irritating) is that I have had sudden bike failures in the past after ignoring such noises!
The noises started on my 100 mile Garforth forum ride recently and I was worried that the bike might break down miles from a railway station. I will be using it on a 105 mile Humber Bridge ride in 2 weeks time and I want to have sorted it out and have done some test rides before then.
I've had a similar problem in the past. The valves on this bike have those little screw-on collars and I made sure that those are tight. Mind you, it is still possible that something is moving around there. I'll check again - thanks.I was cycling with a friend last week and his bike was making quite a high pitched fast rattling sound so we stopped to check it over. We went through everything with Alan keys, all tight enough. I took his front wheel out and bounced it on the tarmac, it rattled, I held the valve and did the same again and no rattle.
I was out with him yesterday and he’d wrapped tape around the valves where they pass through the rims, all quiet as a mouse now.
He has a fancy bike with carbon rims and valve extenders, this may be different to yours Colin but worth checking, I’ve heard of this happening with alloy rims too.
I was about to suggest that you carefully inspect the welds and joins at each spot on the bike, so dropouts, bridges, tube intersections. I had a constant creaking on my Felt, turned out to be the top tube/seat tube weld.Actually... 'creaking' is a better description of the noise from my bike.
I'm about to put another rear wheel on to see if that fixes the problem. If it DOES then I know where to focus my attention. If it DOESN'T then I will start getting seriously concerned about the cranks and frame because I have checked or replaced virtually everything else!![]()
sorted they reseated bearing , the crank arm was loose and tightend up rattling shifters for free so i bought a new pump whilst thereBack to the LBS
BB started creaking again after a couple of miles , i am getting a bit miffed![]()
