bikingdad90
Is the bottom bracket facing round with no flat spots? Is it possible it is slightly misaligned so flexes the chainset when pedalling?
UpdateFeck up
decided to recable the RH shifter on the carrera as the shifting has been sluggish , i have done dozens of cables so an easy job .....
or so i thought
the cable end missed to stop in the shifter somehow and pulled through underneath it and is now jammed in there below the cable exit hole .
The only way i can see to get it out is to drill a hole in the side of the shifter as when you try to push it out from the other side it just jams against the inside of the shifter body .
To top it all i took off the lower plate to gain access and managed to drop the screw that hold it in and i cant find it![]()
But why would it come and go...?Is the bottom bracket facing round with no flat spots? Is it possible it is slightly misaligned so flexes the chainset when pedalling?
44 cm (from centre of BB to top of seat tube)What size frame is it, just out of interest?
I've come to the conclusion that maybe just one ball bearing in the BB has developed a fault. Sometimes the faulty bearing surface might be in such a position as to be load bearing and therefore noisy. At other times, it might have turned in such a way that the damaged bit is not load bearing and therefore quiet.But why would it come and go...?
Putting a new chain on has helped a lot.
I think it was a combination of a semi-worn chainring and chain, plus maybe a little bit of wear in the BB (though that feels pretty smooth when turning the cranks with no chain attached). I also want to try different pedals to see if they may have been contributing to the din.
I found a couple of BBs in my spares drawer which I could try swapping in some time if I have to. I'd have to check whether they were compatible first.
It’s what was available in the size we needed and at the price it was a bargain too. And finally, when we went to have a look at it, my daughter fell in love with it and that was that. The weight difference isn’t much and she’s happy which means she’ll want to ride more. Besides, she’ll have grown out of it in 18 months…@LeetleGreyCells - out of interest why a Moda rather than an Islabike / Frog? I'm curious. They seem OK, just a little heavy for what they are.
For that size frame my son rode a battered old 650c wheel Islabike cross bike (upgraded to 16 speed from 8) alongside a new 650c Felt F95Jr which was extremely good for the £400 purchase price, followed by a 43cm Argon Krypton as a first 700c wheel bike.
