cyberknight
- Land of confusion
greased rear wheel bearings on the commuter as it was very noisy, no grease at all on the non drive side !
greased rear wheel bearings on the commuter as it was very noisy, no grease at all on the non drive side!
thats how it came new from the shopim gussing probably very little thin stuff ib it to start with , factory built wheels for youI wouldn't buy a secondhand car from you!![]()
less than 6 months old , i do routine maintenance you dont have to be condescendingThere is such a thing as routine maintenance you know, where you strip down things like wheel bearings, BB's and headsets and reload them with fresh lubricant. You don't have to wait until they start making a noise before doing them!
Started working on the Raleigh I picked up a couple of weeks ago. Frame cleaned with autosol to remove 40+ years of grime and wheels out. Front wheel re-greased as best I could as it's a dynamo and the rear's cleaned with the internals soaking - gear oil in later.
I'm not sure it's been cleaned since some sort of modifications with shopper shifters / saddle / chain protector. The bike's not moved in 14 years at least and I was told it could have been 30 years since last used.
Should be ready for PBP 23
It'll not be doing PBP - we've got a special bike build planned for that![]()
A tandem?
I had the rear ones from my exact same bike stripped out last week for the 2nd time after a horrible grinding/cracking noise began. Fortunately I seem to have adjusted it correctly this time as it stayed quiet after a good ride out yesterday. I'm not sure how long it will last though as the cup on one side is a bit pitted.. However, todays fettle has been a disaster as my ham fisted attempt to remove my crank arms to get to my BB resulted in me stripping the threads on both sides. I was being so careful to not cross thread the pulling tool that I failed to noticed that the crank arm wasn't moving and I foolishly kept on forcing the spanner around. What an idiot I feel nowView attachment 560451
Stripped front hub as it was a bit naff. Brake pads out ready for new ones tomorrow and this weekend a new Shimano BB coming
OopsI had the rear ones from my exact same bike stripped out last week for the 2nd time after a horrible grinding/cracking noise began. Fortunately I seem to have adjusted it correctly this time as it stayed quiet after a good ride out yesterday. I'm not sure how long it will last though as the cup on one side is a bit pitted.. However, todays fettle has been a disaster as my ham fisted attempt to remove my crank arms to get to my BB resulted in me stripping the threads on both sides. I was being so careful to not cross thread the pulling tool that I failed to noticed that the crank arm wasn't moving and I foolishly kept on forcing the spanner around. What an idiot I feel now..
Any suggestions on what I should do now would be much appreciated. How can I get the 'knackered' arms off short of an Angle Grinder?
