What Have You Fettled Today?
Alembicbassman
Confused.com
Added a retro Zoom stem to the Diamond Back Ascent.
https://www.ebay.co.uk/itm/Zoom-Ahe...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
carpenter
suffolk
I have the same Diamond Back "Ascent" with girder style stem (I love the look, but it is rather long - I feel that I stretch to far when riding the bike).
I am interested in why you chose to change yours and how it changes the feel of the bike.
Alembicbassman
Confused.com
I bought the bike a few weeks ago from the local scrap man. It did come with the 130mm girder stem originally. The Zoom stem is 10 degree rise and 10mm shorter. The head tube and steerer are quite short, so it just raises the bars a bit to make it a little less racy and more comfy. The stack height of the Zoom is quite high, so you won't be able to run the canti hanger under the stem. It fits straight onto the compression ring in the aheadset.
si_c
Wirral
I bought the bike a few weeks ago from the local scrap man. It did come with the 130mm girder stem originally. The Zoom stem is 10 degree rise and 10mm shorter. The head tube and steerer are quite short, so it just raises the bars a bit to make it a little less racy and more comfy. The stack height of the Zoom is quite high, so you won't be able to run the canti hanger under the stem. It fits straight onto the compression ring in the aheadset, the upper allen bolt is just level with the cut steerer tube.
That seatpost :laugh:
Ming the Merciless
There is no mercy
Inside my skull
Oiled chain during a ride.
itboffin
Rolson matted the entire mancave floor, swept clean yet again only for the wind to blow dust and leaves back in, swapped tyres on four sets of wheels and disk rotors on two sets, fixed two punctured tyres one with a 1/2" thorn still in the casing, more dusting of said cave and then a wipe down of chains, plus a half arse attempt at degunking a rear mech.
Swapped out the turbo bike front wheel for an old one, adjusted my turbo setup so the secondary laptop monitor is closer and in a more upright position ....drank some beers
DCLane
Adjusted the NeilPryde's front derailleur for Zwift turbo use. Still not 100% but better.
Also worked on my son's Argon TT bike:
- Dura-Ace 7900 crankset and rear derailleur
- New chain
- New rear disc
- Trued the front wheel as I wasn't happy with 1mm of movement
- LBS have added new, very-fiddly-to-fit, cables as I've been unwell to go with the new rear and re-furbished front TRP TT-specific brakes
Hopefully that'll be working properly for the 2021 TT season as it's been broken for much of the latter part and we've had to bodge parts for him to get on the start line, resulting in several DNF's.
