DCBassman
- The lumpy far South West
Autocorrect to the rescue, s usual!I'm assuming you mean once-expensive rather than once-experience...![]()
I applied my restoration skills to our kettle this afternoon
Before
After
You know that the only possible celebration is to make a
You aren't the only one. I had to do a roadside repair last time out. Bloody cuttings.I'll be fixing a puncture later after washing the mud off the bike. I'm expecting a double flat with the pesky farmer cutting hawthorns on my route today.![]()
@dave r The silver 'L' shaped clips you've mounted at the dropouts (rack mounting point?) are supposed to be fitted with the QR skewer going through where you've put the bolt and should be fitted the other way round - see below from my Van Nic commuter. It'll make the guards a much closer fit.Having had problems with the rear mudguard on my Eastway, I put new wheels on it a few weeks ago and since then I've been having problems with the mudguard rubbing, theres not a lot of room under the brake bridge, and every time I fixed it the problem came back. So I got a set of SKS Raceblade's from Tredz. https://www.tredz.co.uk/.SKS-Raceblade-Long-Mudguard-Set_89347.htm
Taking them out of the packet they looked like a chinese puzle, but they clipped together and fitted without major problems, they're not a full mudguard, protecting behind the brake bridge but not in front, they stop the brown streak up the back and protect the rider behind but not the bottom bracket area, theres only a six inch length in front of the brake bridge. So as I didn't need the front mudguard, the current one works well, I modified the front mudguard and fitted it to the back to turn the mudguard into a full one, it needs a little bit of fettling but I've got no rub now. The only other problem is that they are designed to fit on the axle not on mudguard eye so the stays are too long, something I'll look at later.
View attachment 550888 View attachment 550889
