Sufferfest @JhnBssll been thinking about that be interesting to see what you think.
I'll let you know when I've tried it, people keep telling me good things about it but the name alone is enough to put me off
Had a further fettle today after collecting a new chain and a couple of new inner gear cables from the lbsThe turbo bike is now all back together and functioning rather nicely again 😊 I've tweaked the saddle position slightly since the bars have been raised, looking forward to trying it out later
In other exciting news the bits arrived in the post for my mudguard project so I've had a play with that too 😄 Here are the little mounts I was waiting for...
They suit tubes from 10 to 34.9mm diameter and varying cross sections so figured they were worth a try.
They seem to do the job perfectly, I'll have to monitor them in use to check they don't slacken off through vibration etc but I think they'll be up to the task
With that little problem solved I did some more trimming of the front guard then trimmed the stays to length - very pleased with the result. I also popped the rear guard back on to get a feel for the finished effect 😊
I think it looks rather smart![]()
Not transmission .... hydraulic cooling fans, air con and alternator ...Hydraulic transmission? Didn't know it had survived after BR killed off the Western Region locomotives.
Diesel Multiple Unit. Each carriage has its own engine, allowing for self rescue and independent operation, if a single engine fails the hotel power for the carriage can be provided from the operating units.Diesel-mechanical DMUs then?
Yep, but diesel-mechanical or diesel-electric was what I meant.Diesel Multiple Unit. Each carriage has its own engine, allowing for self rescue and independent operation, if a single engine fails the hotel power for the carriage can be provided from the operating units.
Diesel electric passenger trains are called DEMU's, Voyager is a prime example ..19ltr Cummins Diesel engine, driving alternator, which drives DC traction motor ...in the carriage.... which drives the traction bogie gearbox via a shaft .... less than simple !!!Yep, but diesel-mechanical or diesel-electric was what I meant.
I can still remember diesel-mechanical DMUs powered by AEC Regent bus engines...and those are tough enough to probably still be going!
