Today I've mostly been fitting mudguards to the Pilot Veturi, which has precisely zero fixing points
I've gone for Kinesis Fend Off aluminium full length jobbies and they seem really good quality so far. I've modelled and printed some prototype brackets and got the rear guard nicely mounted but the front is going to be more tricky.
I started by making some basic clamps to fix the stays near the dropouts:
Next up I made a clamp that fits over the chainstay bridge to secure the other end:
This held the guard quite nicely but it still had enough wobble to give me concerns about rattles, especially knocking against the seat tube as there's only around a millimetre of clearance there.
Normally it would be held tight here by clamping to the seatstay bridge but this frame doesnt have one so I decided to make my own...
It's not fixed to the frame but designed to wedge in place. When I've printed final versions off and lined everything up I'll drill the guard and bolt it to the bridge but even with no bolts its completely solid so I'm very pleased
I've since tidied the CAD models up ready to print final SLA parts which should stand up to a bit more abuse
The front is going to be a challenge. The carbon forks are a fairly complex shape which makes it difficult to recreate accurately when the measuring tools I have available are a steel rule and some digital vernier calipers
I've sent an email off to one of the guys at Pilot to see if they're willing to send me some CAD data of the forks which would be a massive help, otherwise I may have to take them off and scan them which would be a bit of a drag
My concept will be to mark the guard up and cut out the section that currently passes through the forks, then print a front and rear bracket that somehow connect together and mount the two bits of mudguards directly to them. This should give a bit more tyre clearance. I'll print more brackets to mount the stays to the lower legs but that bit should be relatively straight forward in comparison
Hopefully I'll have the winter wheels built up soon too, still waiting on the rims I ordered in July 😭
