itboffin
- Marlborough, Windshire
With 0 puncture protection
£6.60 a sprocket and £18 for a chain (I ordered 2). A SRAM GX Eagle cassette is around £150.
Never expected 4 years from a cassette on an MTB. I've eaten a chain ring in that time.
Genuine question, how much difference in the final time does he get from that sort of weight shaving?
None
0 on the front, a bit on the back.
The low weight should help him. He's 53kg and it's about 1.5kg lighter than his race bike.
We've done a back-to-back test between the two bikes (PlanetX vs Cervelo S3) and it's about 15-20 seconds over a mile updill.
Drilling the brake pads? No time saving, but I like drillium . And drilling his carbon chainrings (38/40/42/44/46) would get a bit messy.
I understood he meant that the hill climbing bike is 1.5kg lighter than the road bike.At those weights zero advantage just compromise, what do you mean by its 1.5kg lighter than his bike that doesn’t make sense in that context, unless his bike is +50kg 🙃🤣
Finished mounting SKS Wide mudguards on both left and right rear trike wheels. Obviously with a trike the stays can only be fastened to the inboard edge, so a minimum of four stays per side were required.
Frustratingly, none of the stays could run in a straight line from the fixing points to the mudguard edge - they've had to navigate around brake calipers and seat stays (a pipe bender produced some impressive curves). And the end result looks remarkably like last year's village fete Buzz Wire game.
