Brakes arrived for the commuter this morning
Seems Hope have started shipping calipers with a bleed syringe with is jolly decent of them
You may notice I've been my usual tarty self and ordered some blue bore caps, which also arrived today 😄 I've got a few different sizes of hope bore cap tools and knew I had the right ones for these so had them swapped out fairly quickly...
I popped the rear one on first, bolted it roughly in place and trimmed the hose to length. I had already fitted the hose at the lever end, and run it through some heatshrink tubing with the dynamo wire for neatness. Once it was all the right length and I'd put the barb and fittings on I got the heat gun out and shrank it down
popped the back wheel in to check for clashes and all is good
Same again at the front but minus the heatshrink
This time I had to bend the upper mudguard stay slightly to allow it to pass around the caliper without touching.
Once both hoses were fitted I unbolted both calipers and let them spin around to release the twist in the hose before refitting them - tightening the fittings on these seems to wind the hose around with them so you can build up quite a bit of twist if you're not careful
I'm now off out to dinner and will likely be late home, but will try and get some mineral oil in them and give them a bleed before I go to bed 😊
