Decided to go ahead with the SRAM to Shimano swap on my commuter after a friend offered to buy the working SRAM bits. Set to work this evening removing the RIval 22 bits and got stuck at the rear mech. The main bolt had seized solid inside the mech body - the thread was free as I had copper greased it on assembly, but even after a soak in penetrating oil and a few sharp taps it wasn't budging
I ended up removing the mech hanger and placing it in the vice before sawing through the mech body. This released the bolt allowing me to unscrew it the rest of the way but obviously destroyed what was left of the mech
Fortunately the rest of it was in pretty good nick - the knackered mech also goes some way to explain why I couldn't find anything wrong with the shifter while I was investigating some problems the other day
I popped the new M475 rear hub and R800 cassette on and placed them in the rear dropouts to check everything fits nicely before I build the wheel. I've also fitted the levers and front mech, but still waiting on new brake calipers. Actually I haven't ordered them yet, so the commuter will be off the road for a while
The rims I'll be using arrived the other day, Bontrager Affinity TLR's. The front is 24 hole and the rear 32 hole but having ordered them together from the same shop I at least thought they would match
Slightly annoying, I've asked the shop if they can supply a matching set of decals and, if not, I'll just peel these one's off until I source some from elsewhere
The spokes should arrive at some point so I'll have to strip the hub out of the front wheel ready to start building the new rims up. I popped the tyres and tubes off this evening so we're all set to go again when more bits are here 😄
Wiggle have also upset me having supplied me with an R7000 mech minus the usual hanger. It certainly wasn't advertised as such and the picture showed the hanger fitted but this is what arrived
I've contacted them 3 days in a row so far and they've not given me any answers. I understand they're busy, but when they're sending out incorrect components or components with bits missing you've got to wonder whats going on
