I had a nice long fettle this afternoon
I'd been thinking about how to attach the rear brake hose on the Revel, as despite having a disc brake mount the frame was only kitted out for cables. After a bit of googling I was able to order these:
so I wiped down the areas of frame where I would stick some clips and, well, stuck some clips 😄
Pretty pleased with that, and since nothing else had arrived I went on to the next job... My friend had dropped off his TCR and a box of Di2 goodies
I was pleasantly surprised to find on removing the lower cable guides that there was just enough space to get in to wire the frame without pulling the BB out, result
So without much messing around I quite quickly had the frame wired and the mechs bolted on...
He had sourced all of the correct frame fittings, grommets etc which saved me a ton of time, it's the little finishing touches that tend to take the most work with these things.
Also rather handily Giant had thought to pre-drill a hole I normally have to drill myself, in the end of the bars to fit the bar end junction box
I insist on using these, even thought they're a little more expensive and a little more of a faff, because they're just so much neater. I managed to get it all installed, set up and firmware updated in a little over 4 hours, without ever really hurrying. These installs definitely get quicker the more you do them
Here's the finished bike - I'm not entirely sure I want to give it back
I'm off out to the garage again in a minute to play with the Bianchi for a little while
