I had a similar ticking issue on my Tricross. I went through everything to no avail. It sounded as though the annoyance was coming from the rear wheel so I put a tiny bit of grease in between the spokes where they cross, I also checked spoked tension, I’m certainly no expert but I tighten a few that felt or sounded to have less tension. Problem solved, no more ticks.I have been trying to track down an irritating but elusive ticking noise which only appears when I am giving my singlespeed bike some stick. It usually only happens when I am riding uphill. Lower pedalling forces don't cause it.
It isn't the chain - the old one snapped and the noise is still happening with the new chain.
It isn't the pedals - I swapped in another pair and the noise remained.
It isn't the seatpost/saddle - the bike is still noisy when I pedal standing up.
I am (almost) certain that the tick isn't coming from the front of the bike so it isn't the bars, stem, fork, front wheel, headset or brake hoods.
I wondered about the bottom bracket. I checked it and thought I could feel a little play. I had found a really nice newish Chorus BB in my spare parts box so I swapped that in and... it feels smoother than the old one but the noise is still there.
The freehub is next to be investigated. I found another one in the spares box so that can be substituted for the current one. The new BB is slightly shorter than the old one so my previously perfectly chainline has been lost. It isn't bad now, but I need to move the sprocket by 1 spacer to get it perfect. I can check/replace the freehub while I am at it.
PS I forgot... I went to tighten the chainring bolts and 2 of the 5 are rounded off internally so the hex key slips. I can't make sure that they are tight enough. I'll have to get them out somehow and replace them with new ones. I'll look for a screwdriver with a blade the right size that I can hammer into the holes to get a grip.
Ah, that's one thing that I didn't think of!I had a similar ticking issue on my Tricross. I went through everything to no avail. It sounded as though the annoyance was coming from the rear wheel so I put a tiny bit of grease in between the spokes where they cross, I also checked spoked tension, I’m certainly no expert but I tighten a few that felt or sounded to have less tension. Problem solved, no more ticks.
I struggled to get up the motivation for a ride today so eventually I thought I'd fetch the Kingpin out and finally sort out the Sturmey Archer hub, now that I have the right cone spanner. The hub has some noticable drag so was clearly in need of a service - I've done it the cheat's way by buying a new-old-stock AW hub from SJS and swapping the internals. In the end it proved to be much easier than I'd feared, although cleaning off all the caked on oil/muck before starting took time and I didn't rush the job so as to make sure I didn't do anything silly.
The old internals look clean and in far better condition than I expected so I intend to use them to teach myself how to properly strip and service one of these hubs then put it aside as a spare.
While doing this job I've also changed the sprocket for a 17 tooth as the 18 tooth that the bike came with is a little too low geared for my liking (and an OE 16 tooth might be a bit on the tall side for the local hills). It feels good on a short test ride - looking forward to trying something a little longer fairly soon.
The spokes in the wheel do not actually touch each other, so that isn't the cause of the ticking noise.Anyway, the freehub is off and the main wheel bearings feel a bit rough so I will replace those and see if the ticking goes away. If not, I'll look at those spokes next.
New wheels going on later. Never swapped rotors etc before, fairly straightforward?
