DCBassman
- The lumpy far South West
Attempted to fit cheap ergo bar-ends/grips. Failed due to incorrect manufacture...
White Spirit is my 'cheap and effective' go to cleaner for everything. Don't anybody be drawn in by that eco-friendly 'Clean Spirit' as it is total crap.Given the chain on the recumbent a wipe down with a rag and white spirit. Excess oil,and gunk nicely removed. Waiting for the white spirit to evaporate. Then relube and rewipe chain. Then will also swap turbo wheel for the outdoor wheel.
Also adjusted bearings on the front wheel. Tightened them up a bit. Grease in bearings looks fine right now.
Bits and pieces over the past couple of days with the PlanetX hillclimb bike build stalled as I'm still sourcing a crankset and shifters:
- The Dawes Kingpin's been partly stripped in preparation for new wheels and a re-paint.
- Swapped the Absolute Black oval chainrings from my son's winter Boardman, where he was testing them, to his BeOne Raw training bike. Not the easiest job and, as that's the one we're both currently using on the smart turbo it should be interesting to see what they're like.
- Began work on the Peugeot Tourmalet project; crankset off, brake cable rusted stuck inside the frame freed, bottom bracket removed and re-greased.
- Wrong size front wheel that came on the Peugeot re-greased with new bearings.
- Drillium chainrings with stuck bolt loosened; I drilled out the bolt.
- Tyre onto a track wheel for the Fuji Track Classic; just a grasstrack rear wheel needed now.
That's the nicest ebike I have ever seen
