I just finished a strip clean of the Pilot Veturi. It was a little dirty and I had a slight click from the bb area.
I took the opportunity to respray the custom rear brake mount as it had started to come away - I had run out of rubbing alcohol when I originally painted is so am guessing there was still some coolant residue on it from machining.
I stripped all the old paint off and roughed up the aluminium a bit before thoroughly degreasing, masking and etch priming...
I forgot to take photos of the colour coat and primer going on, but it cured enough to refit in no time out in the sun so back on it went...
In the meantime, while it was drying, I had whipped the cranks out and found the non-drive side bearing of the Hope BB to be feeling fairly rough. Since the click was only present when putting power through the left hand crank I figured it was worth inspecting this further. Unfortunately when I went to remove the BB I realised I had lent one of my BB tools to a friend and of course it was the one I needed
Not wanting to admit defeat I managed to remove the bearing shield and seal from the cartridge bearing without damaging them. The grease looked in good condition on the surface from the side I had access to but I decided to flush it out and repack it anyway. I flushed it through with degreaser first before thoroughly rinsing with water and then allowing to dry in the sun. I then repacked with grease, working it through all the gaps. It feels a lot better now, but isn't quite as smooth as the other side. When I get the BB tool back I'll think about replacing it - I'm going for a ride shortly so will soon find out if it's still clicking
Once all back together I gave the frame a polish - I had read that Pledge household polish brings titanium up a treat and I wasn't disappointed
I'm now off to get her dirty again
