Is it worth loosening and tightening up your rear wheel quick release...that solve my ticking issue that I thought was BB related. Apologies if already done, I read the tip elsewhere and it saved a whole lot of pain.
I have recently changed the wheels so that got done when I made the change. Then I had 2 rear wheel tube problems so the wheel was in and out another couple of times. And then I took it out again to tighten the lock ring. So ... I reckon it has had plenty of reseating/tightening.
The BB is the one thing that I haven't changed/adjusted. It feels okay, no play, and spins well. It has only done about 3,000 dry miles so I'd hope that it doesn't need replacing. It seems to be in nice and tight. It is a fairly cheap Shimano square taper type so it wouldn't cost much to try a new one. If a new BB fixed the problem, then I would sling the old one. If a new BB didn't eliminate the problem then the BB isn't the source of the ticking noise and I'd keep the old one as a spare.
PS I forgot to check to see if the ticking noise is still there when pedalling hard out of the saddle. If it isn't, then that points to the saddle/seat post. The other thing I could try is to pedal hard no handed to see if the bars/stem/headset/shifters are causing problems. (I'm not great at making big efforts without holding the bars so that could be tricky. Anyway, the stem and bars have just been replaced, and one of the shifters removed and serviced so I think the problem lies elsewhere.)
