Recent fettling ...
The right Campagnolo Chorus shifter on my Cannondale CAAD5 lost its clunky clicks last year. It was still indexing but it was becoming increasing hard to be sure that a gear change had taken place, and I thought it was only a matter of time before it packed up altogether so I looked up how to service it. There are some excellent videos on Youtube showing how to do it.
It is a fiddly process, but ok if you take your time and do it properly. If you decide to do the same, make sure that you don't lose any of the parts when you disassemble your shifter. Oh, and there is a washer-like metal plate which needs to go in the right way up. I failed to notice that there is a small indent in the plate and put it in the wrong way up. That does not work ... I had several attempts to get the shifter shifting, but it was jammed. Eventually I realised where I had gone wrong and put the plate in the right way up. I reassembled the shifter and it is now good as new, with a reassuringly positive clunk every time that I change gear!
I have recently realised that I needed a longer stem. (It only took me about 15 or 16 years to finally accept that I am better off with a 'long and low' position rather than a 'short and high' one!) I had an old long stem which I used to check the new position. The position was good but I did not like the stem so I decided to buy a new one that size. I had a stem fail on me once when one of the 2 bolts holding the front plate on stripped its thread (I had overtightened it). I prefer to have the type that has 4 bolts holding the plate on, so there is less chance of a catastrophic failure - the 3 remaining bolts should hold the bars in place long enough to stop!
I had wanted stiffer bars after buying a CAADX last year which has nice stiff oversize bars. I therefore made sure that the new stem was for oversize bars and bought new bars as well. I bought very compact bars which, in combination with my new position, mean that I can finally get comfortable on the drops. The position feels good on the hoods, on the tops, and on the drops.
So that was a reconditioned shifter, new stem and bars ...
In the process of fixing the shifter and fitting new bars, I decided to tidy up the cabling. The cables had been a bit too long before so I shortened and rerouted them. I think they now look a lot neater, and braking and gear shifting are unaffected by the change. I can still rotate the forks through 180 degrees without the cables pulling, so all seems well.
It seemed a shame to do all that and not fit new bar tape too. A mate normally does my taping for me but he was away on his hols so I did it myself. I am not very experienced at that job so the first attempt was pretty bad. I decided to have a second go and carefully unwound the tape and made a much better job of it second time round. Not perfect, but good enough to not bother with a third attempt. I put
Marsas shock absorbing foam strips under the tape to reduce the inevitable increase in road shock transmitted to my hands by the stiffer bars and stem.
So, I now have a much better position on the bike, and the front end looks and feels a lot better. I decided that I would treat myself to some nice (nearly) new wheels too, Campagnolo Neutrons, which I bought from
@gbs.
The Neutrons have a 12-30 cassette which is a subtle improvement on the 13-29s that I have used up until now. Having a slightly higher top gear and lower bottom gear suits the hilly terrain round here without creating massive steps anywhere in the range.
The old chain on the CAAD5 was starting to stretch so I took that off and replaced it with a new one. I cleaned the rear mech and rest of the bike while I was at it. I adjusted the derailleur endstops and tweaked the indexing. The transmission is working very nicely now. The one remaining annoyance is a slight ticking sound when I pedal hard. I have been trying to eliminate this for some time. I reduced it by about 50% but something still isn't quite right, so the hunt goes on!
I am doing some reshuffling of kit. The chain and old wheels from the CAAD5 will go on my 9-speed Basso which will soon be upgraded to 10-speed. The stem and bars from the Cannondale and levers and wheels from the Basso will go on a singlespeed bike which I am building using an old Specialized Allez alloy frame/forks.
I still haven't put mudguards and rack on my CAADX CX bike. I want to get that done before the winter.
My MTB has been out of action for a couple of years with a faulty brake. I'd like to get that back in action again too.
So, I have a busy autumn of fettling ahead of me. All being well, I will have a stable of 5 working bikes before the winter: Best road bike, bad weather road bike, CX bike (which could double up for light touring duties), a singlespeed bike for going to the shops on and for tearing up and down the flattish A646 when visiting friends in Hebden Bridge, and the MTB for offroad rides that are too gnarly for the CX bike.
