As promised :
Step one of 'Project LongLife'
View: http://www.youtube.com/watch?v=YR8kS_-iENI&feature=youtu.be
Proving that the theory is good: Each single LED will be an array of High Output LED's. The controller board I'm using is only getting 5volts from the USB connector.
Eventually power will be supplied from a 9v pack. And have more outputs. IE More LED Arrays
Step two is to add a switch to control the speed of the lights. This will simulate the revolutions of a wheel. IE quicker switch presses = faster wheel revs.
Step 3 is moving to a prototype to attach to a bike wheel in a test bed. Also including using a micro (physically smaller) controller card and using battery power attached to the wheel hub for ballance
Step 4 Prototype testing: Robustness, Light output, Battery life, Accuracy of LED positioning. cleaning of the code on the controller board. Also reducing the weight of the controller and power supply.
Step5 design of a 'final product'
Step 6 Shove it on my bike, and wonder why I was bothered to do this when I should have been doing kilometres .
Step7 Beer.
