youngoldbloke
The screws make wheel replacement faster, but that, in principle, could also be done by accurately locating the closed end of the dropout.
The screws are screws because they can fine-adjust the axle location backwards and forwards. This is necessary to accommodate different gearing (as well as mechanical wear). Changing the number of teeth on the rear sprocket or chainring alters the required chain length, and because chain lengths can only be selected in fairly coarse, 1/2 inch increments, adjustment in the rear-axle-to-bottom-bracket separation is needed in order to maintain chain tension/avoid chain droop.
The first sentence is correct, thats all. How can these screws maintain tension when the chain pull is forward, away from them? They do not stop the wheel moving forward. Chaintugs prevent the wheel being pulled forward, these have NO such function. They simply allow the initial ideal positioning of the rear wheel axle.
