potsy
Rambler
- My Armchair
Great start to the year Baggy, are you going for the 10 miles a day target again?
True, but the closer you get to your target, the less the remaining flab matters. 2 pounds lost out of a target of 20 - super! 0.5 pounds lost out of a target of 5 - that is still 10%. Just think of it as gliding in towards your target. If you hurtled down to it, you'd almost certainly overshoot and end up underweight!... the more you achieve the harder it gets.![]()
that I am not really a cyclist. I joined this site because I like watching the Tours and one day classics, and stayed.
Oh!As the warmer weather is with us, I hope to get more exercise. I should admitthat I am not really a cyclist. I joined this site because I like watching the Tours and one day classics, and stayed.
to only weigh myself in the morning, before breakfast.
That really is a Potsy calling a kettle black.
We have a similar problem. We have one of those 'toe-touch' jobs which powers-up and zeroises when you touch it with a toe. Then you stand on it. Fine, in principle. But the reading can vary by as much as a Kg or more depending on where you stand on the scales.It depends how I stand on the scales. I try to keep them in the same place, in the bathroom on a floor without carpet. I can stand on them, weigh 13st, then think "Was the needle on zero, have I really lost that much?", step off, stand on them again, I it will show 13st 7lb or something equally silly.![]()
Can anyone recommend a really reliable set of scales? One that gives a consistent reading if you stand on it, step off, then stand on it again? That's all I ask. None of this fancy measure-your-body-fat-HR-BP-GI-blood-sugars-braincellfunction-IQ all-in-one-go stuff. Just a simple weighing machine...
Is there a danger that if someone does not eat enough, then they will not loose weight because their body started "thinking" that it is being starved.
