I know your post was not directed at me, but.........I really needed to read this information.........again. Iv'e got caught up in other factors, such as stopping smoking, exercise and like millions of others in the present climate the general pressures of life. I seem to have got into a rut lately and have been close to giving up. I needed to 'refresh' my approach.I do but barely use it. Torn between EM,Strava and MapMyRide
(The info below does not count for muscle mass which can change BMR significantly,tis a guide only)
I took And put it into This
The resulting BMR (Basal metabolic rate if you stayed in bed all day) is 1956.68 (calories)
To calculate your daily calorie needs you need to multiply your BMR: 1956 x the level of activity
The eventual figure is what you would consume per day to maintain the same weight. If you are #3 moderately active then 1956x1.55 = 3031cals.
Since your aim is to lose weight you need to take a small deficit off this figure. Most people would start at -500 until plateau hits (stop losing weight) 500per day deficit over a week is roughly 1lb loss on it's own before you factor in cycling or whatever activity you do.
I worked out the caloric value of your daily eating roughly. 600 cals per day (before evening meal) Add in a couple beers which have no nutritional value (empty calories really) you would still be barely scraping 1800. It's little wonder you are struggling.
This may not make sense but believe it or not you actually need to eat to lose weight. The body simply won't allow any visceral(which packs in around your organs) or subcutaneous fat(the horrible stuff below the surface of our skin) to be burned off whilst you are essentially starving yourself,it's a basic yet somewhat complicated survival mechanism. You've heard of the terms "hitting the wall" or "bonk"? Both of these are related in a way,when you become glycogen depleted and feel faint,nauseous and struggle to maintain pace,you are only relying on fat at this point,it's the same survival mechanism that prevents weight loss when under-eating.
I've missed bits probably![]()
Reading your post reminded me to chill out a bit mentally, and to actually eat more (healthy) food and keep up with the cycling and walking. Thanks
Sorry Andrew, you can have your thread back now
