V brake modulation
summerdays
summerdays
Cycling in the sun
Bristol
Please report back because we are all at a loss to understand the problem here!
I will do if only to say, I didn't manage to sort it out!
shouldbeinbed
Rollin' along
Manchester way
I am confused - the OP is not talking about sticky or rubbing brakes it is poor modulation - i.e. brakes are either too good or not on. Most people seem to be giving advice for brakes sticking on or pushing on one side only.
To me, I think the first thing to try is to toe in the pads a bit more - that way the pad partially touches the rim with the first bit off pull and progressively gets more pad contact as the pull continues. If that fails - maybe time to buy some crap pads, I have loads!
Am I missing something?
People are trying to be helpful to a fellow member on unclear specifics, giving a range of ideas, several already saying the same as you have offered up.
Seems a bit churlish to be having a go at people trying to help summer days think through and around what else might be happening.
Globalti
I still don't fully understand what is actually happening to the brakes but it sounds as if they are sticking on, which would imply:
1 - Broken or dislocated return spring behind the brake arm.
2 - Brake block has slipped and is jamming against the tyre wall.
3 - Brake blocks have been set wrongly and have part-worn, over-riding the rim so far that they are sticking on.
4 - Simple rust or dirt is preventing the brake arms from pivoting.
5 - Sticky cable.
bykeshed
Owner @ Byke Shed Ltd
Willenhall
If you can give the brakes a squeeze yourself and let us know, we might be able to give a more definite answer. Squeeze the lever and look at the pads at the same time to see what they're doing. Is the lever tough to squeeze with little or no movement from the pads? Does the lever pull all the way in before the pads move? Is one pad touching the rim before the other? Is one or both pads fully contacting the rim or is only a part of the pad hitting the rim?
One thing to check that no one's mentioned yet is that the brake cable is properly seated in the stops, from the lever along the frame to the guide pipe if it has one. I get a lot of customers who say their brakes are stuck on and it turns out their cable has slackened enough for the cable outer to jump out of a stop and the ferrule perching itself on the edge of the stop, effectively pulling the cable tight causing the brakes to stick on. In this case, it's possible the cable is so slack that the ferrule is popping in and out of the stop freely, most likely at the lever - when it's out it's pulling the cable enough so the brakes actually work, and when the cable pops back into the stop the cable is too slack for the brakes to work even a little. Literally need to pull on the brake cable outer casing and see if the ends of the casing come out of the stop. Worth a shot?
Jody
Stubborn git
My understanding is you have what we call binary brakes. Its either over the bars or nothing. First thing to check would be toe in on the pads.
summerdays
summerdays
Cycling in the sun
Bristol
On taking a slightly longer look today I decided it was because the lever didn't move very much - it didn't rub the wheel but the pads were quite close. So I have slackened off the cable a little. She is intending to take her daughter out over the hols to the park, and I will have another look when I next see her if it's still a problem.
That was the lever position at brakes fully on.
Globalti
That's a bit tight and the adjuster is screwed right in at its slackest setting. Can the child even reach the lever? She might be grabbing it and pulling it on hard. I would slacken the cable a little; undo the hex bolt that clamps it at the brake just enough to allow a couple of mm, no more, to run through then re-tighten.
Edit: you've done that.
summerdays
summerdays
Cycling in the sun
Bristol
The child was at school when I saw her Mum yesterday so I did the adjustment without them being there. If I catch up with her over the school hols I'll take a look with her on the bike.
