hang about ,
if he is on a 39 x 11 and i'm on a 53 x 11 , should'nt i be faster ?
Yes. If the setup is identical in all other respects (sprocket, cadence, wheel diameter), then the 53T will go further on each revolution than the 39T
hang about ,
No, because if he is on a really small cog at the back and you are on your biggest (which you shouldn't be) then he will be going faster than you. That is where the gears ratios cross over. I still can't get my head around the cogs I'm 'not meant to use'...why are they there in the first place?
if your only cycling 4 miles in 20 minutes your probably not useing much in the way of anything m8
14how much harder will it be to turn the 53 x 11 than his 39 x 11
the question was is it an efficiant way to exercise for 20 mins , the answer is still no ,
