Thanks Mr Jamie for your comment on the positioning of the HRM transmitter after the posts that went before you. I raised the transmitter slightly so that it sat directly under my pecs and went out on a 24 miler which I last did on 26th October and have to say the HRM results are remarkably similar. MHR 208 (211 previously) and Average HR 143 on both occasions.
I took Arsen Gere's advice and monitored my HR more closely and this is what I found.
1. Mostly my HR is between 120 - 135 BPM and I can control it so that it rises/drops in single increments.
2. When my legs start working hard my HR reading rises above 140 and then jumps in large increments 140 to 156 to 169 and upwards. There is no smooth transition and continues erratically jumping/dropping by 3,4,5 BPM.
I tried this on different sections of the ride by increasing my HR until it read 139 BPM with no problem at all but as soon as I increased my effort and my HR rose above 140 it would jump straight into the 150's and next into the 160's and 170's.
I assume the contact with my skin is OK because the majority of the time my readings are below 130 BPM which seems OK to me. I am in the same riding position (still in the saddle) when they become erratic above 140 bpm so the contacts must still be working fine.
Is this a transmitter problem, a Garmin 305 problem {I bought both second hand) or is there something else that I am missing?
I have done a reset on the Garmin but that didn't make any difference.
Any other advice please?
