Not really sure what my gears are as my bf changed the triple set I had previously to what he calls 'man' gears![]()
Then ask him to change them back.
Uhmm, sounds like the modified bike and the kind of riding don't suit you.Thanks I choose the grass verge on Sunday and hence no injury to speak of only a bruised pride! was first club run with 6 guys![]()
Pah - I was a man the last time I looked and I use tiny gears when I have to!
(Admittedly, I am using them less often as I get fitter, but it is good to have them in reserve for 'special occasions'.)
It sounds like you would have been better to have kept the triple. I have triples on both of my road bikes and my mountain bike, and I use all of the gears.
No kidding - 3 years ago I actually would have had to use a mirror or lean forwards to check my gender because I had moobs and a 55" waistline when I got ill, a health problem not entirely unrelated to the surplus fat!I suppose now you have lost all that weight ( and well done for that) you do not have to use a mirror to check.
I can be slow-witted and weak-willed, but the warning I got was clear enough to make me take serious action!I only got up to a 42 down to a 32, all credit to you Colin.
Hi Louise,
There has been some good tips on this thread, and although it isn't always possible, anticipating stopping (or even perhaps a likelihood of having to stop) is a head start. I unclip fairly often in anticipation of a hazard or having to stop, only to have to clip back in again without the stop.
Backing the release tension off a little is definitely worth doing, and if you are new to clipless pedals, holding on to a wall or something steady and just practicing the clip-unclip action a number of times will be a real help. It will become second nature soon enough, and to my mind, the benefits of clipless pedals far outweigh the few negative moments you might have in the early days of using them.
I can still get caught out on my MTB if I'm grinding up a particularly steep and muddy climb when the back wheel slips and I'm over before I know it.
Try not to let the odd incident knock your confidence, you'll be fine!
I must admit, on my road bike, I just try to give a little kick just to give me that tiny extra bit of forward motion, then unclip on the right (just the way I do things) just as the pedal reaches the bottom of the stroke. That way, I can use a bit of weight on that leg to assist the unclipping action, and my foot is nearer to ground anyway. Not saying this is THE way to do it, but it works for me.
