iggibizzle
- blackpool
I should have said more of a costant smooth rotational movement rather than 'pull up'. Although I do push and pull at same time if it's a hill of doom.
Er, I have never thought about it - I just do it! (Thinks back to last hilly dismount ...) Right, I push the left pedal over the top of the pedal stroke and start to twist my heel out as the left crank is roughly horizontal so my foot is coming off the pedal at about the bottom of the stroke.Thanks - not sure what happened with me, just think I ran out of steam and was probably at a snails pace before unclipping but if I had done it earlier I would have lost even more power. Do you unclip at top or bottom pedal position?
I didn't intend to leave it till the last minute but didn't want to admit defeat too early so only stopped when I couldn't pedal anymore. Not sure when I should have done it then?I've got SPDs and have always set the release tension to the absolute minimum without ever unclipping accidentally. If I anticipate that I'm grinding to a halt on a steep hill (or on the flat for that matter), I unclip in good time. I'm not racing so I don't see the point in leaving it to the last second.
Not really sure what my gears are as my bf changed the triple set I had previously to what he calls 'man' gearsEr, I have never thought about it - I just do it! (Thinks back to last hilly dismount ...) Right, I push the left pedal over the top of the pedal stroke and start to twist my heel out as the left crank is roughly horizontal so my foot is coming off the pedal at about the bottom of the stroke.
That works every time if I do a planned stop. The only times I have been caught out have been unplanned stops, such as the example I gave above when a stupid motorist selfishly drove into the bit of road that I was about to ride up!
Another suggestion ... It helps to have really low gears on your bike to reduce the likelihood that you would have to dismount in the first place. With the low gears on my road bikes (26/28 and 28/29) I am ok up to at least 15%, can usually get up 20%, and only start to struggle on long stretches steeper than that. (Ah - beaten to it by @Boon!)
Thanks Jim, I don't really want to give up on the clipless pedals so might well give these a go. Was worried that you could unclip by accident easily thoughLouise - try shimano multi release cleats (sh-56) before you bin the whole spd thing .i had a few near topples ( well a few full topples as well) with the standard single release cleats( sh-51) but now I have the multi release I feel a lot better,Iv never unclipped when I didn't mean to,imo there's just enough hold to position and keep your foot on the pedal but release with almost any sort of twist.
Theyv def made me a lot better and now I don't even think about unclipping, an all round better option ( for me - and u by the sound of it)
Thanks I choose the grass verge on Sunday and hence no injury to speak of only a bruised pride! was first club run with 6 guysNothing to do with unclipping but always make a mental note of the road ahead and keep one eye on driveways and turn offs as these can be a good escape route to stop and the last resort a grass verge to come off as it s a bit softer than tarmac..
PS.. Lower gears can mean the difference to staying upright or not..![]()
Pah - I was a man the last time I looked and I use tiny gears when I have to!Not really sure what my gears are as my bf changed the triple set I had previously to what he calls 'man' gears![]()
Indeed, don't let your boyfriend dictate what or how he thinks you should ride, when it's you at potential riskPah - I was a man the last time I looked and I use tiny gears when I have to!
(Admittedly, I am using them less often as I get fitter, but it is good to have them in reserve for 'special occasions'.)
It sounds like you would have been better to have kept the triple. I have triples on both of my road bikes and my mountain bike, and I use all of the gears.
