cyberknight
- Land of confusion
No i heard he only comes once a year because mrs claus does not like a chilly w ***ySanta only comes when you talk about presents on CycleChat?
Use a small magnet to locate the screws/nails that fix the plasterboard to the joists.Brilliant as long as you know where your beams are.
Or you can buy a battery operated stud detector (Use a small magnet to locate the screws/nails that fix the plasterboard to the joists.
or just thump the ceiling and drill into the bits that don't sound hollow.... In my experience, electronic stud/cable detectors are pants. Regarding 'detecting' electrical cables... don't drill directly above a light switch or directly below a plug socket... common sense is far more reliable than an unreliable device.Or you can buy a battery operated stud detector () for about a tenner, also handy for detecting electrical cables before drilling
OK as long as you're sure whoever put the wires in had common sense! I've found cables taking surprising detours inside plaster and voids by using a decent cable detector. Well worth the money.In my experience, electronic stud/cable detectors are pants. Regarding 'detecting' electrical cables... don't drill directly above a light switch or directly below a plug socket... common sense is far more reliable than an unreliable device.
yes to all but ANYTHING under padded shorts, i found out over the last few rides until i realised it's the lycra base layer i am wearing under my shortsTurning your bike upside down, wearing underpants under padded shorts, cross chaining, pointing your QR levers in random directions, wearing competition jerseys that you haven't won, these are all things that are worth doing out of sheer devilment because the purists say you shouldn't.
get one of these if you have the spaceI'm feeling slightly guilty after adding to some of the gently mickey taking posts this topic has generated and would now provide a more serious suggestion.
Have you considered one of these cycle hoist devices?http://www.ebay.co.uk/itm/like/1307...3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108
The hoist is cheap, stores out of the way on your ceiling and can be easily adjusted to get the bike at just the right height for the task in hand. Whilst it may not be suitable for holding the bike for heavy engineering work, I find it adequate for inspecting/adjusting brakes, mudguards, chain, gears etc.![]()
i prefer exposed beams my selfBrilliant as long as you know where your beams are.
hang on i'm here!Assuming your all grown up theres something you should know about "santa " , its within the the same same of thought as the PUNCTURE fairy![]()
PRESENTS PRESENTS PRESENTS PRESETS PRESENTS!Santa only comes when you talk about presents on CycleChat?
we do all our wiring our self and take photos and do diagrams or where everything is before plastering or plaster board or wooden boarding or concrete block depending where/what building it is. so assuming there isn't a wire moving fairy we should be ok!OK as long as you're sure whoever put the wires in had common sense! I've found cables taking surprising detours inside plaster and voids by using a decent cable detector. Well worth the money.
hows the spare wheel behind the Swedish flag held up on the ceiling? could we have a closer pic by any chance?
I ordered one from maplin earlier today. They've already cancelled the orderIf you have place to mount a bike lift buy one
I don't think it did the back brake on my Hardrock Pro any favours. The lever came back to the bars after it had been upside down but was ok after a few pulls. It was spongy when not used for a while so probably needed bleeding but I think turning the bike upside down contributed to this. Apologies for the "serious" answer!I thought I read on here once that it may cause issue with hydraulic brakes, not sure on the accuracy of that though?
