I'm new to tubs and honestly did''nt find it half as much as a faff as I was expecting, so don't be afraid. Despite what has been said IMHO they defo ride better, I have clincher and tub versons of the same tyres (Vittoria Open Pave's) on tub and clincher versions of the same wheels (Shamals) so able to do side by side comparisons, and on ride feel I'd take the tubs every time, though they are not cheap and repair/replacing its not as easy as clinchers.
Getting the tyres off was easy enough, too easy with the taped tubs I took off so I've no confidence in using tape. Even the very well glued on Wolber Piste came off fine once I got the technique (a plastic chopstick worked a treat to ease the tyres away from the rim).
Glueing new ones on was easy, but messy, I got glue over my hands, clothes and the rims, but I'm sure 'll get better at it. And the centering was also fine, I had no bleeding hands or thumbs or any of that.
Admittedly I've not had a puncture on the side of the road yet, but I'll report back when this happens. At the moment I'm carrying a spare pre-glued tub and some latex solution. You do have to carry around some different kit. The syringe I got for injecting the latex solution I thought would make me look like I was carrying around a spare vial of EPO, but its much bigger than that, it makes it look like I'm riding around the countryside lookng to do some rogue artificial inseminating!
As the tubs are quite new if I get a puncture soon I'm going to attempt to open them up and repair them myself, (at home not at the roadsde) but when they get a bit more use on them I'll probably revert to some latex solution.
As a novice to tubs (I have some used Planet X 101/82 with vittoria corsa) can you do anything to alleviate punctures - some kind of tyre slime?
When I was looking into what latex to get, a review somewhere (sorry cant remember where) recommended Orange Seal, so I got a 16fl oz bottle from
Tredz, and I got a the Caffe Latex syringe, you can either unscrew the valve core and inject directly into the tube, or it comes with an adaptor to fit directly onto the presta valve and inject straight in. Apparently this will not last forever, about 3 months I'm told, and you have to ensure once they've got latex in that you keep air in them of the inner tube sticks to itself and can tear when inflated.
Anyway as said above, you've taken the plunge so you may aswell give them a go and see. Good luck.
