livpoksoc
- Basingstoke
After picking up a puncture last week (Schwalbe Pro One TLE 700x28), couldn't get it to seal so put a tube in to get me home.
Back in the garage, I discovered I appear to have three punctures that aren't sealing. Two x 5mm cuts and a smaller pinhole puncture. I appear to have been able to seal one of the 5mm cuts with a plug, but the other won't seal despite my best efforts with the tedious plugs. The pinhole one also doesn't seem to want to seal itself, but think that may be down to not being able to actually run the tyre properly whilst it is compromised.
Whenever I pump the tyre up, it reaches about 60 psi and blows and leaks. Plug still in place, but doesn't want to take the strain of full inflation.
So the question is, how do I now fix this cut? I've seen videos suggesting that dedicated tubeless patches are good, but others dismiss them entirely.
In these supply chain buggered times, I have frantically sought a spare set of Pirellis to keep on standby should I be unable to fix this, but overall not convinced this is a sustainable solution as this would in effect be my third set of tyres on these wheels in a year and I've only done 1800 miles in that period. (the first were continental GP5000s I have abandoned due to being a bastid to get on my rims).
FWIW I have several small cuts in the tyres that have sealed successfully that would have otherwise had me replacing tubes by the side of the road over the year, so I am as yet undeterred by the switch to tubeless.
