T.M.H.N.E.T
- Northern Ireland
It comes with the tubeless valve kit but may be available on it's own
I have read that if you lay the wheel on the ground, you can (carefully) stand on the tyre to pop the bead.
Not had to try it myself yet though.
That happened to me in the pouring rain in a gateway not far from Gatwick airport a few years ago. I was using Continental inner tubes and the fecking pump kept extracting the core.
Have you ever had problems with your Apollo lunar landing craft? they can be tricky too ..Never, ever, ever experienced this. But then I only own push fit presta pumps.
Best investment I've made for tubeless tyres is an 'airshot' reservoir, makes seating them a doddle.
I think that was probably what I did in the end. I must have sorted it out somehow as I'm not still there. That was one of those rides, one damn thing after another. Everything went wrong. It was later on that ride I learned that it's impossible to keep a tube dry enough to attach an instant patch when it's raining.I had that once with a conti tube, not in the pouring rain, tightened core with pliers and it was fine, but I don't use conti-tubes anymore.
With all these extra gubbins needed on a ride, I'm thinking it would be easier to just carry spare wheels. I already have the carriers:
It is expensive but I picked mine up for £48 (not being picky) and there's 3 of us that ride together with 6 bikes between us and a couple of wheelsets for each bike so worth it.I have one of those, although sixty-odd quid is a fair bit for a tool used very occasionally.
In my case, my venerable Halfords track pump wouldn't punch enough pressure into the reservoir which increased the spending to close to £100.
That may well be a sensible purchase for you (in your circs), but that is £48 that the bike industry wouldn't have seen without this trend ...It is expensive but I picked mine up for £48 (not being picky) and there's 3 of us that ride together with 6 bikes between us and a couple of wheelsets for each bike so worth it.
I've seen the video's and indeed they are very good, I just couldn't be ar*ed for less than 50 squid.And a slight improvement on the financial investment on that
This us an easy hack with all the bits there for you in place and cheap
I Was lucky as an old one was busy so i kept some parts from the bust one for future use
Theres you tube vids of it as well
Basically a garden spray
Remove the water " dipstick " from the top of the bottle and its fittings
Put the cap and fittings back on the water bottle
Remove the yellow tube after the nozzle
Fit the water dipstick in place of the yellow tube
The other end of the water dipstick firs tight as onto the valve
Pump it up until at its max when you may hear a little hiss out of top of relief valve
Open the green nozzle spray and whack the air into the tyre...no probs with rd tures
Occasionally with larger mtb tyres you have to get the tyres on as near as possible to help it along but I have always got there
I also made with stiff lying around a tube that bypass the green nozzle as this is some what a needle valve
So I replaced this with a quarter turn 15mm copper valve available any diy shops ...this let's the air into the tyre much faster than the needle nozzle
However the needle nozzle usually works
Is that a bad thing though?That may well be a sensible purchase for you (in your circs), but that is £48 that the bike industry wouldn't have seen without this trend ...
