Fab Foodie
- Kirton, Devon.
Could be something as simple, but excruciatingly painful, as the Piriformis playing up.
A small muscle in the buttock, which when aggravated causes (for me) unbearable pain, as it ‘shares’ the sciatic nerve.
https://learnmuscles.com/blog/2017/09/24/piriformis-syndrome/
I'm a pain in the arse already!
But your article brought me to this which is very interesting....
I have lost some weight recently, so much around the aerobelly that my existing belts and short no longer fit. I dug out an old belt that I could only ever do-up on the first hole and now can do-up on the 3rd. Have just bough a size down in shorts too.
The old belt is of course slightly tighter and also narrower so the pressure is greater. It's not impossible that this is also part of the problem.....
Note: Meralgia Paresthetica
The sciatic nerve is not the only nerve that can be compressed and cause referral into the lower extremity. The lateral femoral cutaneous nerve, which exits from the pelvis into the anterolateral thigh between the Pelvic boneand the inguinal ligament, can also be compressed. When this occurs, the resulting condition is called meralgia paresthetica.
Because the lateral femoral cutaneous nerve is solely sensory, this condition results only in altered sensation, usually tingling or pain, into the anterolateral thigh (see accompanying figures). The most common causes of meralgia paresthetica are wearing low-rise jeans or a belt too tightly, being overweight with increased weight carried in the anterior abdominal region, and tightness of various hip flexor muscles, including the Iliopsoas
and/or tensor fasciae latae. With the increased rates of obesity in the United States, the incidence of meralgia paresthetica will likely increase in the future.
Although local low back pain or spasming may occur, lumbar pathologic discs often show no local symptoms at all and present with only lower extremity referral symptoms. Pain, tingling, numbness, or weaknesses that are referred in the lower extremity should be a red flag that a disc problem may exist. However, this does not mean that all lower extremity referral symptoms come from a lumbar disc bulge or rupture. Other conditions such as piriformis syndrome (see next section) or meralgia paresthetica may also refer symptoms to the lower extremity. Although a reasonably accurate assessment can be made with the appropriate orthopedic assessment procedures, if a lumbar disc condition is suspected, the client should be referred immediately to a physician for a definitive diagnosis.
