cheadle hulme said:Nice bike for a freecycler! Unfortunately, those wheels are a weird 24" french size. Not only will braking in the wet be very poor, but tyre choice is limited.
I found these http://www.sjscycles.co.uk/category-Tyres--24-(540)-345.htm, but I'm sure if you search for other 24 inch (540) tyres you may find something else.
It could do with a new chain (£10 from any decent LBS) but you may find the chain jumps on the old sprocket. decathlon in Stockport do reasonable 5 speed sprockets for these. The mudguard just needs a new bolt at the back (again LBS) and some bodge/TLc on the front bit.
Call it £50 all in to get it roadworthy, but you can get a similar style bike from Decathlon with alloy rims and modern brakes for £129.......
Not nice bike if not from a freecycler?
I wanted this though because I wanted to learn how to clean it/ make it work... whereas if I just bought a new one, I wouldn't learn. Also I don't want a new bike because I want a slightly rubbishy one to take to uni, in the hope that it won't get stolen.
Thanks for explaining the tyres. I'll have a look at what I can find... why will braking in the wet be difficult because of the tyres?
I've since attempted to clean the chain with hot water, then rinsed it, then sprayed some WD 40 on it. In the process I managed to do something which now means the chain won't turn
What do you mean by 'bodge' and what's 'the front bit'?
