The theory is that if you fill up when it is cold, the fuel is more dense, so a gallon of dense fuel is more than a gallon of fuel when the ambient temperature is warmer.I am interested, carry on.
The theory is that if you fill up when it is cold, the fuel is more dense, so a gallon of dense fuel is more than a gallon of fuel when the ambient temperature is warmer.![]()
Not sure I have enough to last until summer though, also the fuel in the tank underground is much the same temperature year round. Now expansion rates, interesting that one, about .015% So about 9p per gallon difference from max to minimum. I cannot remember when weights and measured check my pumps when I had a petrol station if they checked temperature as well.![]()
It's because you live in a soft water area so only need half as much.I know we need to expect some "settling of contents" from the factory; but really? This is a newly opened box of soap powder...
It isn't any more than 2/3 full. Nearer 1/2 full.
Yours etc.,
Concerned of Ayrshire.
Clearly the war against obesity is an expensive one.And it's even more hilarious that they don't think we'll notice that the price stays the same instead of coming down.
Depends how many bodies you put in there first.Has anyone dug a very large hole and then tried to fit all the soil back in again, to be honest I am not sure what that has got to do with it either.
I wonder how they disguised the smell of burning oil ?Going off topic, but sort of on topic, there's speculation that Ferrari were manipulating the breathers so oil vapour itself was being burned as a fuel at high engine loads. I suspect their road cars do much the same after 20 or 30 thousand miles.
Just as a qualifier or background regarding the e symbol, there are very strict and legal tolerances allowed when applying it . There are two specific tolerances T1 (lets call it ideal weight) and T2 (underweight but only by a small amount) . There is a small percentage (say 2 to 5%)) that are allowed between T1 and T2 but nothing should be allowed below T2.Sold by weight not volume, there's probably an e mark next to the declared weight to confirm it.
Although considering the amount of boxes produced, how much could the manufacturer save on cardboard if the reduced the height of the box by 2"?
2.5% here, and 2% in mainland Europe.Just as a qualifier or background regarding the e symbol, there are very strict and legal tolerances allowed when applying it . There are two specific tolerances T1 (lets call it ideal weight) and T2 (underweight but only by a small amount) . There is a small percentage (say 2 to 5%)) that are allowed between T1 and T2 but nothing should be allowed below T2.
The idea is that most packs may be slightly overweight, a small amount of underweight is acceptable. This is done for efficiency in packing.
So even if you get an underweight pack, it's not underweight by much and it wont happen very often.
