The Rail Enthusiast thread
Andy in Germany
I think Class 20s are still used by DRS on weedkilling trains. They were the first diesels delivered under the 1950s Modernisation Plan and a few are still going nearly 70 years later. Single cab design means they are nearly always seen in pairs, nose-to-nose. A mere 1000hp each.
English Electric diesels did pretty well among all the duffers turned out by other manufacturers. Their only real failure was the Baby Deltic. The Class 40 was a bit meh, being too underpowered to replace Gresley steam Pacifics, but was reliable enough.
Wasn't one of the problems with the Baby Deltics that their engine was designed to keep going, not stop-and-start as was needed for the traffic it was used on?
rogerzilla
Not sure. I know it had a lot of reliability problems which were kind of sorted out just as BR decided to eliminate all classes with a small number in service. The big Deltics had their own issues which were manageable until BR took over maintenance from EE. Both had horrendous emissions of smoke (2-stroke diesels).
Due to a change of plans, in what was happening today (originally Scarborough & Whitby), daughter & I headed out for a (late) morning in Harrogate
I drove up the A1 to Wetherby, through the town centre, onto the A661 through Spofforth (1), & hence on to Harrogate
Before we even got to Spofforth, I had a detour, to the site of the old Station, off Linton Road in Wetherby
(there was also a 'RaceCourse' station)
504473
504474
504475
I oh so want that A1 sign!!
504476
Pre signs; https://www.geograph.org.uk/photo/5798829
http://www.disused-stations.org.uk/w/wetherby_second/index.shtml
Scroll down to Wetherby
http://www.lostrailwayswestyorkshire.co.uk/Church Fenton Harrogate.htm
504477 504479
504481
1. Visited earlier in this thread, for the viaduct
NorthernDave
Never used Über Member
Interesting to note that now Northern are phasing out the Pacers, I've spotted a few single car Class 153s (aka Dogboxes) on the Caldervale line, presumably on the Leeds - Bradford - Halifax - Huddersfield service which was almost exclusively operated by Pacers.
Given the longstanding overcrowding on these lines, a lesson in being careful what you wish for, perhaps?
classic33
Leg End Member
"Platform 31/2 at Bradford Interchange!
Been on a few from Leeds now, usually in the hour before evening peak period.[/I]
Passed through Hunslet this morning, after giving daughter a lift into Leeds
It seemed wrong not to have a little visit
Hunslet Engine Works
Jack Lane
505740
505741
505742
The redundant signs are still there, but there's nothing within the yards, & no national network connection anymore
505743 505744
https://britishlistedbuildings.co.u...ny-offices-city-and-hunslet-ward#.XlKreEB2vIU
http://www.leedsengine.info/leeds/hunslet.asp
https://www.geograph.org.uk/photo/986098
https://www.geograph.org.uk/photo/4575011
http://www.quarryhunslet.mste.co.uk/public/intro.php
rogerzilla
I'm doing the letters on an old GNR gate sign in instalments, because it's pretty tedious work. I expect they did them with a roller when they were new. I have a garage wall covered with stuff like this.
Funny how the typesetter grabbed the wrong sized "A" for "AND".
classic33
Leg End Member
Area around that "A" appears to have damage. Maybe the "A" got damaged and was replaced with what were to hand.
UPDATE & NEW IMAGES
Whilst out with daughter this morning, I pulled over to photograph quite possibly the last remaining (visible) structure connected with the narrow-gauge railway that ran between Ledston Luck Colliery, & Peckfield Colliery, adjacent to the Leeds-York main-line, where it was loaded onto wagons
I was driving from Castleford, along the (A656) 'Barnsdale Road', which becomes the 'Ridge Road', after Peckfield Bar (where A63, Leeds - Selby crosses it)
Below this occupation bridge is a cutting, albeit very heavily overgrown...
I've noticed the Gate before, but never quite made the connection
http://www.geoffspages.co.uk/specials/ledstonluck.htm
This link, should(!!) open a 1954 OS map of the area
http://maps.nls.uk/geo/explore/#zoom=15&lat=53.7901&lon=-1.3432&layers=10&b=1
This picture shows the line, alongside the RidgeRoad, with the Leeds-York railway cutting visible
Recently, I've been told that the occupation bridge, & cuttings aren't the only survivors of this colliery narrow-gauge
This afternoon, after a visit to Rothwell Library, I took the long way home
Through Swlliington, down to the 'Old George Roundabout' as it's locally known (where the 'Selby TurnPike'/A63, crosses the 'Aberford & Wakefield TurnPike'/A642), then up past Garforth Cliff, to Peckfield Bar (again, where the A63 crossed the 'Barnsdale & Leeds Road - HookMoor Branch)
Having managed to pull up safely on this rather busy road, & taking advantage of gaps in the foliage...…. without falling on my posterior, I took what photographs that I could
Apologies for quality, but it was grim weather and the auto-focus was trying to focus on branches instead!!
Lo & behold!, two blocked up apertures!!
To the north side of the A63
506325
To the south-side of A63
506326
The cutting/'tunnel' are more or less, where the power lines pass over the A63
(just left of the 'P' of 'Peckfield)
https://www.geograph.org.uk/photo/2754979
NorthernDave
So Northern is no more (well Arriva Rail North, anyway) and now everything will be sorted as the government take over running their services.
Apart from the fact it's the same frontline staff, running the same unreliable trains on the same creaking and chronically underfunded infrastructure, what could possibly go wrong? :rolleyes:
classic33
Leg End Member
Bear that in mind when the 142's are returned from Neville Hill.
Then think about how you'll get to & from platforms 1 & 2, in Halifax, when they close the footbridge.
