Technical Question: Chip Butty
OCD to line up chips in a chip butty
  • Total voters
    65
theclaud
Openly Marxist
Swansea
Line up, put optimal sizes together so butty filled and maybe add a second layer. Max number of chips and lashings of marg.
welsh dragon
You can't compare waffles to chips, that's just wrong.
Definitely no waffles. That's just wrong
[QUOTE 3024801, member: 9609"]enough butter so that it drips out as you eat.[/QUOTE]
Just a scraping., scrape it on and scrape it off.
Chips have to be lined up in a butty, any that have slight overhang need re positioning and a smallet one put in its place, once the first layer is in place, you need to do it again but in a brickwork or horizontal/vertical pattern, this is the only way a chip butty should ever be constructed..............end off
[QUOTE 3024809, member: 9609"]Marg !
Good grief even if you have to pedal an extra 50 mile to justify it, dump the marg and enjoy a good deep spread of butter.[/QUOTE]
Utterly butterly.
